I believe that the caliper mounting brackets are the same as the Chevrolet parts (should have the 2 3/8" allen head through bolts holding the calipers on). They did switch to a different style of caliper, but I think it was early 80's. I'm not sure about the spindles. You need to get the Dana numbers off of them and cross reference.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
Thanks Jason. The calipers do have the allen head screws holding them on but on the Autozone web site it has a different part number than the Chevy ones. I haven't looked at the spindles yet.
Yes, but the Jeep conversion is the same as the Chev conversion. You use the GM (or Jeep) spindles, calipers and mounting brackets with Ford 5 lug rotors.
Jason
__________________
guess i just got spoiled to have a disc brake dana 44 out of a ford laying around
Nah!!! Now if you had a HP Dana 60 with disc brakes "just laying around", then yes, I would agree that you were spoiled. If you did, I may just have to make a trip up there and take it off of your hands.
The guy contemplating totaling his F350 just for the front end...
Jason
__________________
i had a D60 just laying around, bought it for an old project, ditched the project, kept the 79 kingpin axle for about 6-8 months, someone offered me a ludicrous amount of money, so i sold it
