Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-18-2005, 09:58 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
new engine design
http://www.dynacam.com/Product/Desig..._overview.html
Neat looking but will it be practical.
  #2 (permalink)
Old 07-18-2005, 11:13 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
interesting... no wasted strokes, a fourcycle type that can run like a two cycle... no more wasted strokes. I don't see why it couldn't be put to practical use, if it produces the power they claim. I can see that it should, since it can push the piston back on the exhaust stroke with a power stroke...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 07-19-2005, 08:10 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is online now
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
interesting, but looks expensive
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #4 (permalink)
Old 07-19-2005, 09:04 PM
rusty70f100 rusty70f100 is offline
Garage is empty, add now
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Looks like oil control will be a problem. You've always got a cylinder on the bottom, no matter how you rotate it. If it burns oil it'll never pass emissions. Interesting idea, but I dont see it happening.
OBTW, it looks like they adapted a swash (or wobble) plate compressor to make an internal combustion engine out of it.
  #5 (permalink)
Old 07-19-2005, 09:24 PM
brown79 brown79 is offline
brown79 is starting off with a positive reputation.
looks like a hydraulic motor/pump to me
__________________
1979 f150
4x4 460 c6 np205
Quote:
Originally Posted by NumberDummy View Post
I guar-an-tee ... I'll ignore ... whatever you post!
  #6 (permalink)
Old 07-21-2005, 09:14 PM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
For those that know aviation you understand how that validates the system to a degree- it has to perform to make it in that field- even under experimental. I'd say it sounds like a helluva product. Time will tell. wish I had money to lose in an investment- could be a rich man someday or wiser.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #7 (permalink)
Old 08-08-2005, 12:48 AM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
That thing looks almost identical to an A/C compressor, the exception being that it has opposed pistons instead of a single set operated by the cam or eccentric plate in the middle.
The valve train would be a nightmare, I can see that. I note that the Wankel engine had fewer moving parts, but it had its own developmental troubles - mainly seals that went out around 70,000 miles.
The one advantage I see is that it has no radical shapes to cut out or machine. Wankel side casings had to be difficult to machine.
That cam in the center though, I wonder how tricky the bearing setup is?
It's different, I give it that. Something it has in common with the Wankel though is that it appears to be a design adapted from a type of pump. If you think about it, most compressors are set up very similar to a piston engine.
What would be real impressive is a turbine engine based on twin-gear oil pumps!
~Wolf
__________________
Think outside of the box - especially if you built it yourself
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
