Transmission Diagrams - Ford Truck Enthusiasts Forums
Old 07-18-2005, 04:59 PM
Weezie12 Weezie12 is offline
Weezie12 is starting off with a positive reputation.
Does anyone know where I can find diagrams for a 1988 Ford F150? Preferably online if possible. Thanks.
Old 07-19-2005, 03:40 PM
jamiesan jamiesan is offline
jamiesan is starting off with a positive reputation.
what are you looking for? SPECIFY!!
Old 07-20-2005, 09:09 AM
The diagram of the parts. There is a small pin about 3/4 to an inch long that fell out into the gears. And I don't know where it goes.
Old 07-20-2005, 10:15 AM
95X15 95X15 is offline
95X15 is starting off with a positive reputation.
What transmission? What diameter pin?
Old 07-20-2005, 10:48 AM
Transmission in a 1988 Ford F150 straight 6 300 engine. I don't know the diameter of the pin.
Old 07-20-2005, 10:51 AM
low92flareside low92flareside is offline
low92flareside is starting off with a positive reputation.
Stick or auto. If its a stick, did you by chance remove the shifter recently?
Old 07-20-2005, 11:14 AM
Stick. And I did remove the shifter recently, because the transmission was making weird sounds. And it wouldn't move when I put it into gear. So I took the transmission out, and that is when I found that little pin, and also some shavings that were metal.
Old 07-20-2005, 11:49 AM
You need to remove the shifter again.
Remove shift boot. Remove the torx screws holding the shifter in. Lift out shifter.
There are 2 pins on either side of the shifter just below the plastic bushing. I'd stop at the local dealership and pick up a fresh bushing and pins.
Old 07-20-2005, 12:39 PM
I know about the pins you are talking about. They are longer than the one I am talking about. I don't know where it goes.
Old 07-20-2005, 01:21 PM
I'm not sure how much more help I can be. Transmissions aren't my specialty. Try posting a pic, hopefully someone will recognize it. Try leaving some more info on your trans as well. My first thought was that you have the Mazda M5OD, but I just read back and it doesn't mention specifically.
I've got this...
http://www.frontiernet.net/~miketoni...%20Rebuild.htm
Old 07-20-2005, 01:49 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
you need to go to ford dealer. bring your part, he will pull up diagram for you and print it out.
you need to learn to describe truck, problem and needs better so we can help you.
Old 07-20-2005, 03:47 PM
I concur, go to dealer, even if you don't have the part to show him, their parts room computer has the diagrams you seek. Just be sure to get the trans. door code to correctly I.D. your tranny. Sounds like mazda 5 speed to me, too.
Old 03-22-2012, 04:58 PM
mike_7857 mike_7857 is offline
mike_7857 is starting off with a positive reputation.
Nevermind found solution.
Vacuum Diagram Acronyms? stevieray 1987 - 1996 F150 & Larger F-Series Trucks 17 03-22-2011 11:42 PM
460 Vacuum Diagram idahocrewcab Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 01-12-2011 02:19 PM
Wiring Harness diagram lshort Electrical Systems/Wiring 9 04-02-2002 01:00 AM
wiring diagram 1961 - 1966 F-100 & Larger F-Series Trucks 7 11-08-2001 07:55 AM
Wiring Diagrams pmastriano 1978 - 1996 Big Bronco 6 02-11-2001 10:11 AM
Tags
1990, 1996, 95, breakdown, diagram, diagrams, e150, f150, ford, manual, mazda, parts, schematics, speed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
