Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-17-2005, 10:50 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Transfer case quit transferring: Advice needed
Hey all.
My wife and I took a three day weekend to go out of town with the trailer for some R&R. Completly uneventful trip down there and all around sightseeing. Truck was acting normally and not making any unusual noises at all. We concluded our hike, got in the truck, and proceeded down the hill. I was coasting, in 6th gear, engine turning maybe 1300 rpm. Without a sound, the engine suddenly dropped to idle and started coasting as if in neutral. I pulled over and fiddled with the gear shift, nothing. I cycled the transfer case between 2wd, 4h & 4l. All I could get was 4l. No high range at all. I cycled the lever again, pausing in the neutral position to spin things a bit. Still no high range. "Oh GREAT!" I thought, "I'm stuck on the top of Mt. Rainier 120 miles from home and all I have is low range?" So I stuck it in low range and started down the mountain. I made it less than a mile and then some horrid scratching noises started coming out from underneath and then everything was disconnected, as if the driveline was not even there.
I am positive it is not the clutch. I can hear it engage if I let out the pedal fast, hear the slight but noticable drop in engine RPM as it spins up the transmission. But there is no power transfer after that.
I rolled under the truck and I can see where to separate the two halves. I am writing this plea for help to see if anyone has seen this before and can offer some tips.
Thanks in advance,
Dan.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #2 (permalink)
Old 07-18-2005, 12:21 AM
touchofgrey touchofgrey is offline
Garage is empty, add now
touchofgrey is starting off with a positive reputation.
So, your ok as long as your in 2WD? or is that gone too?
__________________
2000 F350 CC 4x4 LB Dually
SCMT, Wicked Wheel, Mods, H2o Inj.,IC Mist, Gauges, 91 gal. Aux.Tnk, Air & Bags,Tugger Kit, Trans. Cooler, Hi Cap.Trans. Pan, and Dif. Cover, list: Prop., HD TC.
  #3 (permalink)
Old 07-18-2005, 12:28 AM
See if this give you some ideas.
Mechanical Operation
In the 2WD mode, torque from the transmission is transferred to the front input shaft, which in turn drives the output shaft that drives the rear axle.
The 2WD to 4X4 HIGH shift is accomplished when the 2WD to 4X4 HIGH shift fork moves the lockup collar to engage the drive sprocket to the rear output shaft. The drive sprocket turns the chain which turns the front output shaft driven sprocket on the front output shaft and the front driveshaft.
The 4X4 HIGH to 4X4 LOW shift is accomplished when the 4X4 HIGH to 4X4 LOW shift fork moves the shift collar to engage the planet carrier to the main shaft. Torque for the input shaft is then transmitted through the sun gear, which then turns the planets. The planets, which are now engaged to the output shaft, provide a gear reduction.
Here's a little more:
§ CYCLE the transmission through all gear positions with the transfer case in 2WD and 4X4 HIGH. If there is noise in the neutral position or in some gears but not others, DIAGNOSE the transmission. If there is noise in all transmission gear positions, OPERATE the transfer case in all positions. If the noise is only present in 4X4 HIGH, DISASSEMBLE the transfer case; REFER to «Section 308-07B». CHECK the input gear, intermediate, and front output shaft gear for damage. REPAIR as necessary. If the noise is only present in 4X4 LOW, INSPECT the planet gears and sliding gears for damage. REPAIR as necessary.
__________________
  #4 (permalink)
Old 07-18-2005, 07:18 AM
1999 Ford F-550
Thanks for the info touchofgrey. Reading that makes me think the shift fork is broken. The transmission, as far as I can tell, still works fine. And the way that it failed on the mountain, all indicators say transfer case, not transmission at all. You wouldn't happen to have a diagram of the transfer case you could email me? I'm off to Helminc right now to get the full cd-rom, but I need to get started right away. My 5th wheel is still stuck 100 miles from home and I am paying for the site until I get it out.
__________________
Dan
  #5 (permalink)
Old 07-18-2005, 11:57 AM
1999 Ford F-550
Bump. Anyone else seen this before? Advice? I'm going to start pulling it now and will check back later.
__________________
Dan
  #6 (permalink)
Old 07-18-2005, 12:41 PM
Azu607 Azu607 is offline
Azu607 is starting off with a positive reputation.
Hey Kwik:
My Father-in-law lost his a couple of weeks ago hauling chicken feed home. He was quite a ways from home so he had a repair shop install a rebuilt. I looked at the All-Data repair site and it looks like quite a job to pull that thing apart. Lots of special tools required. I don't know if you are familiar with All-data but when you are on the road it is a great site for repair procedures. It is about $15.00 a month to subscribe per vehicle. I am not affiliated with them at all, just think they are helpful. http://www.alldatadiy.com/
Cheers, Kelly
  #7 (permalink)
Old 07-18-2005, 01:30 PM
U_B_LO U_B_LO is offline
U_B_LO is starting off with a positive reputation.
Why isn't it the front input shaft to the transfer case? If you were in 2 wd when it happened and have nothing now I don't see how it could just be the shift fork. Keep us posted. I've not seen this before, although with the older chain drive transfer cases,(NP208) they seemed to break the shift fork a lot.
__________________
1981 Bronco with transplanted 390 and NP205 and 3/4 ton running gear.
  #8 (permalink)
Old 07-18-2005, 01:50 PM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
I've never tore into the one on my 02. But i've taken apart a few BW1356's.
Removing the rear driveline and taking the back half of the case off should reveal your problem, if it is a broken fork. There are a few sliding gears in the there, and a chain that drives the front output shaft. The rear output shaft is inline with the input shaft, and the hi-low fork determines which gear couples the input to output. I know this is for the older style TC, but it might help you out.
Have you tried lifting the rear and spinning the tires/driveline to see if you can hear where the noise is coming from??
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2" Level; 4" StraightPipe; DiPricol Optix; DP F5; EBPV Brake; Foil Delete; Disabled Waste Gate; OverBoost Annihilator; Fogs w/ Parks; EBPV LED, DieselSite Billet T-Stat Housing, ART Front Rotors
-Rich
  #9 (permalink)
Old 07-18-2005, 01:54 PM
1999 Ford F-550
Quote:
I have the transfer case off and on the bench. I can operate the lever and get it to work in one direction, go the other way, something lets go inside and it free wheels until I operate the lever again. Ideas before I pull it apart?
__________________
Dan
  #10 (permalink)
Old 07-18-2005, 01:57 PM
1999 Ford F-550
Thanks for the info. It looks similar in design. Any tips before I tear into it?
__________________
Dan
  #11 (permalink)
Old 07-18-2005, 02:16 PM
cgl cgl is offline
I found this thread while googling (is that even a word?) to find you some info on the NP273. It seems you're not the first to experience this!
http://www.ford-trucks.com/forums/sh...d.php?t=102120
Unfortunately, I'm not real sure what you can do to rig it up in 2-hi to get you home... Or atleast somewhere it won't cost you to stay... I suppose you could always pull into a dealer's lot and stay there while they fix it.. That would be funny! Well, untill you get the $2000 bill of course...
Hope this helps!
on edit.. I see we have the NP271 Manual shift TC's...
__________________
-Rich
  #12 (permalink)
Old 07-18-2005, 02:25 PM
Quote:
Check your "internet" email.....messsage for you waiting.
__________________
  #13 (permalink)
Old 07-18-2005, 02:32 PM
cgl cgl is offline
Quote:
Could you by chance send me a copy of it as well?? Now I'm curious to see what I've started...
__________________
-Rich
  #14 (permalink)
Old 07-18-2005, 03:02 PM
1999 Ford F-550
Got your message, I can wait. I ran out and bought the correct sockets to get the flanges off. Oil is drained and am going to start opening it up. If I get to something where I think I need a diagram, I'll stop.
Thanks for all the advice guys.
__________________
Dan
  #15 (permalink)
Old 07-18-2005, 03:08 PM
Ah...yes......patience is a true virtue Grasshoppa..
__________________
Tags
205, case, cost, diagram, divorce, dodge, installing, np, np208, np271, nv273, pull, rebuild, transfer, transfercase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
