F350 Rear Brakes - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
F350 Rear Brakes
Old 07-16-2005, 06:17 PM
gholtum gholtum is offline
gholtum is starting off with a positive reputation.
F350 Rear Brakes
I have a 1997 F350 Crew Cab Duely (diesel) and I want to replace the rear drum brake pads.
The dealer service manager says on some, the drums come off without pulling the axle shafts.
Anyone know if this is true and if so, how can I tell before starting the job?
Gary
Old 07-16-2005, 06:22 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You can't really tell before starting the job, unfortunately. Just get ready to pull them in case you do need to.
Old 07-17-2005, 04:51 PM
Thanks for the quick reply.
If I pull the wheels off will it be obvious?
Gary
Old 07-21-2005, 04:04 AM
PDX-PLT PDX-PLT is offline
PDX-PLT is starting off with a positive reputation.
Yes, it'll be obvious. Assuming you have the parking brake off, the drums can be taken off if the they are loose. Otherwise, you need to pull the axle shafts, remove the hub and drum, unbolt the drum from the hub, etc.
I just did the rear brakes on my 1995 F-250HD. At least that year, the F-250HD's and the F-350's use the same Dana 80 axle.
Interestingly, the Chilton manual for my truck said the drums were not loose; it was wrong, but I didn't notice until I had pulled the shaft on one side and undone the outer bearing! So I had to buy a $30 hub nut tool for this axle in order to proper re-install the bearing. At least it has a pretty slick "clip-stop" system for setting bearing float.
Old 07-21-2005, 07:25 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 07-21-2005, 11:09 AM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.brokebronco is gaining momentum as a positive member of FTE.
You sure you had a Dana80 in a 250? It should have been a 10.25 which is why the drum slid off.
I never messed with a dual axle so I am unsure about the mounting system.
Chris
Old 07-21-2005, 11:40 AM
3 of 7 3 of 7 is offline
3 of 7 is starting off with a positive reputation.
My 95 F350 DRW has the Sterling 10.25 and you don't have to pull the axles.
Old 07-21-2005, 05:17 PM
andym's Avatar
I know the SRW trucks all use a sterling 10.25", but I was under the impression that the dually rigs use a Dana 70 or Dana 80.
Does anyone know for sure? 3 of 7 - are you sure your dually is a sterling? Does it have the fill plug in the cover?
Old 07-21-2005, 06:48 PM
Yes , mine is a sterling, I just did the brakes and had a 355 ring and pinion installed, the fill plug is on the front left of the housing (not on the rear pan)
*****edit***** I changed front right to front left, I was upside down and backwards when I put the new oil in it!
Old 07-21-2005, 07:22 PM
Quote:
To be honest, I don't know for sure if its made by Dana, or which one it is. I was going by the description on the package for the hub nut tool, which said it was for the Dana 80 used on 250-HD's and 350's.
Mine is the 10.25, used on 250HD's and 350's SRW's that year. I missed the note that his was a DRW.
This was the first time I did drum brakes. What a pain. Disc brakes are almost fun in comparison.
brake starter problem gazbiz 1999 to 2016 Super Duty 3 12-14-2007 11:37 AM
Rear Disc Brake Conversion 94 f350 Happyreefer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-02-2007 10:55 PM
F-350 DUALLY rear brake drums stuck/rusted? on gary_b Brakes, Steering, Suspension, Tires, & Wheels 0 10-16-2006 08:46 AM
I need bore sizes! gahi 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-13-2006 08:06 AM
1988 F-350 Rear Brake Drums MeanOlBill 1999 - 2003 7.3L Power Stroke Diesel 8 06-21-2001 09:53 PM
Tags
1963, brakes, f350, ford, install, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
