Lengthening Frame
Old 07-16-2005, 09:06 AM
Matt66's Avatar
Matt66
Matt66 is offline
Lengthening Frame
I am looking at some late 80's early 90's frames for my crewcab swap. From what I can tell they are about the same width, 37", as trucks through the 70's, so a swap to them should be no problem. What I can't find is one that is the right length. There are plenty that are the 133" wheelbase, but I would like one that is 139". If I could find a supercab frame it would probably be right.
Could I lengthen a 133" frame about 6"? The rear spring hanger would then rest on the extension. Or, does this fall into the same category of cutting a frame in the middle to shorten it, as in it won't be strong enough to hold the rear spring. Even though people do it.
FYI. I am interested in the late 80,s for the IFS 4x4, 351 efi, overdrive tranny and other later model technology.
Thanks, Matt
Old 07-17-2005, 05:26 AM
jowilker's Avatar
jowilker
jowilker is offline
Matt, I hope to encourage you by saying, Take Your Time, rushing along will only make you spend more money & time than necessary.
You can find what you need if you will continue searching.
John
Old 07-17-2005, 08:03 AM
Matt66's Avatar
Matt66
Matt66 is offline
You are so right.
Thanks, Matt
dani9678
11-14-2009 05:11 PM
ccg61504
16
03-08-2009 12:57 AM
jrwhitey_2000
12-18-2005 10:06 PM
irondragon79
05-12-2003 01:50 AM
SeabeeBuilder133
01-08-2003 08:08 AM
Quick Reply: Lengthening Frame
