How do I Lower a 2005 Lariat?
I have a 2005 F-150 Lariat Supercab and want to lower the rear end. I bought 2" lowered shackles and installed them. They beat the bed to death on bumps and hard turns. This is the first time that I have run into this problem with shackles. The shackles popped and banged every time the truck moved. I had to remove them to get rid of the noise. Now I have two big dents in the bed where the shackles kept hitting. Is there anything else that can be done without a major undertaking?
Okay, not THAT was funny Lash.
Bama, where they shackles meant for your truck? seems odd that they would hit into the truck like that. I've read on these boards of many people doing the rear lowering thing and not having a problem.
One solution I did see was to remove a block from under the rear shackles and then install the stock leaf spring clamps from a 4x2, for proper refitment.
fatfords
02-08-2023 07:56 PM
