Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-13-2005, 07:02 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
Garage is empty, add now
wolfmanagh is starting off with a positive reputation.
codes P0263 & P1293
I started having some problems with a 2000 E450 rough idle yesterday, first time around I had (P0272 Cylinder 4 Contribution) and (P0275 Cylinder 5 Contribution)
I replaced both those injectors and now they don't read bad anymore and the idle cleared up a little.
Now I get #1
p0263 cylinder # 1 Contribution
So I'm just wondering if anyone knows what exactly is contribution?
And sometimes I get this here code too (not all the time), so I'm guessing when I was in there for #5 I might have pinched a wire.
p1293 high side open bank 1 (right)
__________________
2001 F250 4X4 SD Offroad Diesel
http://www.ford-trucks.com/user_gall...id=186898&.jpg
And now 3/08 a new to me 98 E350 PSD
  #2 (permalink)
Old 07-13-2005, 07:04 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
How did the wiring harness's look? They are famous for giving trouble.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #3 (permalink)
Old 07-13-2005, 07:12 PM
wolfmanagh's Avatar
it looked alright. The connections were tight. Yes I know that really doesn't mean too much. Also everytime I did the injector buzz test it came back no codes each time the test that pops these codes up is the one that is done with the motor running.
__________________
  #4 (permalink)
Old 07-13-2005, 08:56 PM
soutthpaw's Avatar
soutthpaw soutthpaw is offline
soutthpaw has a good reputation on FTE.soutthpaw has a good reputation on FTE.
did you replace the valve cover gaskets and then zip tie or superglue the inner side of the plug, sounds like on of the clips on the side of the plug is coming loose. you may have reconnected it in the process of removing the valve cover and not noticed. this is a common problem for the SD series
__________________
DJ
ASE Master Auto Technician.
2001 Excursion 4x4 7.3 with Lot-o-mods (Daily Driver)
Project: 94' Isuzu FSR Crewcab 12' flatbed dump
Tags
2000, 2005, 73, code, diesel, e450, f250, fault, ford, harness, obd, p0263, p1293, power, sd, stoke, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
