Need help with OBD-II Code 0401 then 0402 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-11-2005, 01:38 PM
propellerhead's Avatar
propellerhead propellerhead is offline
propellerhead is gaining momentum as a positive member of FTE.
I got an 0401 EGR Flow Insufficient last week. I cleared it and it showed up again after a couple of days. I replaced the EGR Valve and the 0401 reappeared. I replaced the DPFE and the code did not reappear. Great!
About a week later, I got an 0402 EGR Flow Excessive. Argh! New EGR Valve. New DPFE. The hoses to and from the DPFE to the tube look decent. They don't appear to have any build up inside.
Has anyone traced their 0401 or 0402 to the tube?
My first intinct is to replace the EGR valve again, assuming the one AutoZone gave me is stuck open. Is there any servicing I can do to it first? Like maybe soak it in carburator cleaner? Or spray it with WD-40?
Thanks.
Old 07-26-2005, 11:28 PM
MazdaRangerGuy MazdaRangerGuy is offline
MazdaRangerGuy is starting off with a positive reputation.
There's your answer - AUTOZONE...
Put the original EGR valve back on.. the dpfe was your only problem..
Also get a motorcraft DPFE
Old 07-26-2005, 11:33 PM
Unfortunately, I threw the old EGR Valve as soon as I got done installing the new one.
On the bright side, the code cleared itself.
/me scratches head...
Old 07-27-2005, 10:52 PM
Well, I just heard from my son. He said the CEL comes on for a few minutes, maybe 30 mins, then goes off on its own. He said this happened 3-4 times already. So, is it the EGR Valve or the DPFE?
Old 07-28-2005, 11:00 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Hard to say. But if you are still getting both 401 and 402 codes, then I think you have to suspect a component/circuit probelm as opposed to a blockage or leak.
There are a couple of excellent links covering the Ford EGR/DPFE system in detail at the Ford Scorpio site:
http://www.fordscorpio.co.uk/egrsensors.htm
http://www.fordscorpio.co.uk/egrmonitor.htm
Even though the Scorpio is not a North American vehicle, it nonetheless still uses the same exact EGR/DPFE system as that found on our Fords, so the information set forth is both accurate and relevant.
Old 08-05-2005, 06:47 PM
I think the original DPFE caused the P0401. I think the "zoner" EGR valve is causing the P0402. Has the 0401 returned after replacing the DPFE? Or are you just getting P0402 (Excessive flow) now?
Old 06-14-2013, 09:14 PM
BillStevick BillStevick is offline
BillStevick is starting off with a positive reputation.
a 401 on a F150 is usually the ports clogged with carbon coming off the throttle body. You have to remove the throttle body, get at the ports with carb cleaner and coat hanger. Clean em' out good, and voila, no more 401 code.
2000 F150 mredington 1997 - 2003 F150 5 12-04-2015 08:23 PM
P0402 Troubleshooting : Jumper the Lines? cixelsyd 1997 - 2003 F150 3 07-12-2013 09:46 AM
P0401 EGR 96_4wdr Aerostar 5 02-22-2013 12:07 PM
P0402 code on a 2001 Ford Expedition 4.6L djones35 Expedition & Navigator 1 08-30-2012 02:22 AM
P0402 code bbsitum 1997 - 2003 F150 6 03-29-2012 08:02 PM
Tags
0401, 0402, 0402obd, 11, 401, 402, 98, code, codes, egr, ford, ii, obd, obd2, po
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
