Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-10-2005, 01:39 PM
blsd49's Avatar
blsd49 blsd49 is offline
Garage is empty, add now
blsd49 is starting off with a positive reputation.
Cool Oil splatters
I have a '49 F3 w/ flat 8. Oil or grease splatters from behind fan and pulley.
My manual says that no lube is required but my mechanic says it is?
Any input?
Brian
  #2 (permalink)
Old 07-10-2005, 04:07 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Here's a link for the same question - I'm too lazy to type it over BTW 48-52 are the same
http://groups.msn.com/FordFlathead19...30105182447738
  #3 (permalink)
Old 07-10-2005, 04:57 PM
blsd49's Avatar
Thanks mtflat
I'm gonna' run up to the shop right now and check it out.
Thanks,
  #4 (permalink)
Old 07-10-2005, 06:33 PM
blsd49's Avatar
Looks like the oil is coming from the point on the hub where it mounts.
I did remove the screw and nothing dripped but was wet with oil.
Maybe it was overfilled and now most has ended up inside the hood and on the engine!
I'll keep an eye on it but am afraid I may have to pull it ...soooo tired of splattering oil!
bb
  #5 (permalink)
Old 07-21-2005, 11:09 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
So, did you get the problem taken care of ???
  #6 (permalink)
Old 07-22-2005, 07:36 AM
blsd49's Avatar
Not yet....looks like I will have to take the fan and hub off , clean them and start over.
Just been super busy lately , but soon!
  #7 (permalink)
Old 07-23-2005, 12:38 PM
51ford fan's Avatar
You might want to install a repair kit from Mac's
  #8 (permalink)
Old 07-23-2005, 07:32 PM
blsd49's Avatar
I looked on-line and in my Macs catalog but didn't see a repair kit?
  #9 (permalink)
Old 07-23-2005, 07:54 PM
51ford fan's Avatar
Angry
Quote:
Sorry, I have the 226 6 cylinder in my 51 with the fan on the water pump.and I totally forgot your 8 has the two water pumps with the independent fan, I'm brain dead I guess. I will look, and if I come across a kit for the fan I will let you know.
Look in Mac's Early Ford 1932 to 1948 catalog, they list Fan Spindle Mounting Bearing And Gaskets
Also LMC Truck Parts Catalog has the fan bearing and gaskets listed in there catalog.
Hope this helps
Rod
  #10 (permalink)
Old 07-23-2005, 08:07 PM
blsd49's Avatar
Not a problem. I will look at LMC. Thanks for the feedback.
Brian
  #11 (permalink)
Old 07-23-2005, 08:15 PM
51ford fan's Avatar
Wink
Brian
OK I found it I think, it's the Oil Filled Pulley And Hub Assy for a 48 to 52 Pickup. Part #21A-8603 @ $59.95
It's in the Classic Auto Parts Catalog www.classicautoparts.com Phone 800-654-3247
  #12 (permalink)
Old 07-23-2005, 09:21 PM
blsd49's Avatar
Wow ....you are fast!
I looked it up and that is the part.
Looked at mine and between the pulley and the mounting bracket (#'s 5 & 6 in the LMC catalog) there is what looks like a fiber type 1/4" gasket...that is where the oil is coming from. I don't see that called for in any catalog. I think that the mechanic who did the rebuild got some bad info when it came to that part. Other than this small but troublesome problem the engine is great.
I thought that it would eventually run out of oil to splatter but that doesn't seem to be happening. The mechanic will be back next week so I can ask him about it.
Thanks for all your help. I will order the assy.from Classic Auto.
Brian
  #13 (permalink)
Old 07-23-2005, 09:44 PM
51ford fan's Avatar
Brian, I'm glad to have been able to help you out. I work as a swimming pool operator for the city. I have Bell & Gossett pumps that transfer hot water from the boiler through the heating system. The pumps have an oil reservoir to lube the pump shaft. If I don't keep them full of oil they will seize up. I would hate to be out for a drive in your truck and have that fan seize. (just a thought)
Rod
  #14 (permalink)
Old 07-24-2005, 09:18 AM
blsd49's Avatar
Rod, And a good thought it is....I wouldn't really run it dry...just my frustration talking!
I ordered the assembly last night. Will let you know when I have it back on the road.
And hopefully soon some photos.
Brian
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
