You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I’ve got a rough 49 f-1 with a flat 6. What would be the best way to get two Carbs and Duel exhaust on it. Im guessing I would need two intakes and two exhaust manifolds, cut them up and peace them bact together. Has anyone done this?
Also what kind of carbs would I put on there?
And finally does anyone know where I can get an aluminum head?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Aluminum heads for the Ford flathead 6 are very rare, saw 1 advertised in an old hot rod mag from the 50's. Never seen 1 today. There have been 6 cylinder dual intakes made, but they are kind of rare, saw 1 recently at a swap meet, but it was too pricey, and I'm pulling my 6 for a flathead 8.
Can't say I've ever split manifold, but I'm sure it could be done. The dual exhaust could simply be a 1 into 2 set up if it's too difficult to split the mani, of course, you don't get as much HP as true duals, but you'll gain a couple.
__________________
Gary-
'46 Ford 1/2 ton
'07 Black F-150 XLT SuperCrew
plus a handful of other Fords
Kansas Kustoms will take your exhaust manifold and make a dual exhaust out of it for around $200.00 including shipping. Get ahold of Christopher2 over on the 48 to 60 forum he just had one done. He also picked up a dual intake off ebay a couple months ago.
Mike Yoder
620-662-0040 or 620-200-3500
113 E. Sherman
Hutchinson,Ks
67501
at Kansas Kustoms will cut a single manifold and make a dual out of it for the old flathead 6. You don't need two
For dual carbs I have been told you can use two of the factory caburetors. That is what I am using. Look at Vintage Speed for dual carbs if you need some setup help. I found one two carburetor intake in the past year and it is sitting in my garage with rebuilt carbs waiting to be installed. I paid dearly for that intake. I didn't care I wanted a 254 flat with with dual carbs abd a dual exhaust.
I would also look at side draft webers if you want multiple carbs, cut the intake keeping the runners and have the ends machined with an adapter made to fit.
As for the aluminum head I have been looking also no luck at all.
-Thanks
__________________
I am in the process of getting a 1949 F3 with a 226 Flat 6 roadworthy. I like to drive them, then decide what I want to change. I think it helps with motivation.
Hey thanks for the info guys. I guess ill have to keep my eyes open for an intake and im shur that sending my exhaust mani in would be a better idea than trying to butcher it myself.
Mike does a good job and has worked with a lot of cast iron manifolds. I went with him for the experince he has. I didn't want to mess with a leaky manifold.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
