Tranny swap-starter problem! Help!
This is a conversion from a 3 speed manual to a C4. Both trannys are off 302's. While finishing the install I decided to use the 3 speeds starter as it was fairly new. The new flexplate, and the old flywheel are both 164 tooth, so I figured it would pop right in. I've done this before without problems. This starter's bolts line up fine, but the starter hangs up on part of the hole cut in the C4's spacer plate. It's VERY close, but it won't pop in.
Can I save this somehow, or do I need a new starter? Thanks.
Sorry about that. In my application I will be going from a 71 302 3-speed to a 89 AOD. When I list the mid 80's starter for a small block and the early 70's manual starter I get two different numbers (AZone). Even if both are 164 tooth they may be different throw or offset of flexplate/flywheel ring gear, right?
Steve
Steve
You have to use the starter for the year of the transmission.
I have a 1971 351W out of a car in my 1983 F150 with an AOD Transmission in it and I am still using the original starter that came with it in 1983. My 1983 had a 302 in it and I wanted a 351W.
A 1971 and a 1983 Starters have different part numbers and I do not know what the difference is.
Flughafen Leiter
07-27-2012 06:19 PM
hayden01
09-12-2011 07:22 PM
rollpan
08-04-2009 01:30 PM
