Ford ECU Laptop Programming Software - Ford Truck Enthusiasts Forums
Computer Chips & Tuners SPONSORED BY:
Old 07-09-2005, 02:44 PM
RoboFights RoboFights is offline
RoboFights is starting off with a positive reputation.
Yes , I am asking that age old question. Is there a laptop software that can program a factory Ford 5.4L ecu without chips or modifications? I know, its a stupid question, but still hoping something is available. I think aftermarket chip manufacturers are making to much moola, and highly guard programming information that is probably easy to aquire or copy. Lets revolt against the capitolist regeim, and distribute curves and information freely.
Best Regards,
Robofights
Old 07-09-2005, 02:55 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Not again... what story is it this time? If you're so against capitalist companies, quit your job and join a commune.
Old 07-09-2005, 09:32 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Yes, there is.
Paul Booth's EEC Editor as distributed by http://www.moates.net is probably the only free choice. Then you need $100 of electronic gizmos to attach your laptop to the EEC, and you can go from there.
The reason why chips sell so well is for several reasons. Many people do not have the time, knowledge or ability to reverse engineer an OEM EFI system. Having done a few myself, it's not a task for the meek. Plus, it's time consuming. If you want to learn EFI and do something very strange, fine, go for it. But for the average guy, buying a $125 chip and plugging it in and "rebooting" the vehicle is quick enough for gratification it's worth the $125. Assuming your combination of power toys doesn't change often.
Old 07-09-2005, 10:02 PM
rpollard rpollard is offline
rpollard is starting off with a positive reputation.
Sounds like a yes to me. But think about this it took me 20 hrs to tune my last truck engine and you have to have a buddy with you for safty. With the tuner they do all the work for you.
Old 07-09-2005, 10:31 PM
frederic's Avatar
Yes, but most tuners that sell custom chips make educated guesses based on what information you provide them.
Which gets them darn close.
But often, putting in your own time you can do very well.
A friend's mustang had a custom chip done, and his 'stang ran so much better than stock, but with my 40-LED wideband meter (DIY off a website), we quickly discovered they really just played with the rev limiter and the shift points, and really didn't increase fuel at higher RPMs. His stang was still running too lean.
Added fuel in increasing amounts above 2500 RPM, and viola, the car felt even better.
To each their own, I personally would rather DIY, learn something, and make the custom tuning very precise for my specific application.
Old 07-12-2005, 02:03 PM
FTE Ken's Avatar
Get an SCT Racer's package. You get to play with all the settings yourself without having to start from scratch and reinvent the wheel. All the basics are there (and the advanced stuff) with a lot of the parameters explained. My time is worth something to me.
Old 07-31-2005, 05:32 PM
flitemedic flitemedic is offline
flitemedic is starting off with a positive reputation.
Say Ken,
I'm not sure if this is the right forum, and if not you can shove me in the right direction. I recently discovered, out of neccessity that a OBD I computer in a 1991 F350 5.8L(manual tranny) cured my problems in my 1990 E150 5.0L(AOD) and also I had a friend who was given a 1994 F350 w/7.5L that the No.1,4,5,8 injectors did not get the pulse signal so I gave him my disclaimer and told him about the computer swap and we found one at a salvage yard for 10.00(compared to that of 200.00 and a possible months wait if we sent his to be repaired. Yes, the junk yard computer from a '91 F-350 w/a 5.8L worked like a champ. I may be telling you old news, but a lot of the guys I've told about this were surprised that it worked. Any comments would be appreciated.
Old 08-01-2005, 08:16 AM
02FX4Dude's Avatar
02FX4Dude 02FX4Dude is offline
02FX4Dude is starting off with a positive reputation.
Quote:
Originally Posted by frederic
...but with my 40-LED wideband meter (DIY off a website), we quickly discovered they really just played with the rev limiter and the shift points, and really didn't increase fuel at higher RPMs. ....
Any chance you could point me/us in the right direction to the plans for that wideband meter? It would be much appreciated.
Brian
Old 08-01-2005, 08:25 AM
frederic's Avatar
Quote:
Brian
Sure.
http://www.diy-wb.com/
The project is actually requires two pieces. The wideband which is at the top of the page, in full detail, and the display unit, which is about 2/3 of the way down by clicking "displays". There are several choices for displays, with my preference being the "Bruce Row 40 LED" version.
Old 08-09-2005, 11:27 AM
FTE Ken's Avatar
Quote:
Originally Posted by flitemedic
Say Ken,
Have you checked the air/fuel ratio to make sure its on target?
complete 700 hp mustang efi electronics fnfast88 Ford Truck Parts for Sale 0 06-16-2015 01:27 PM
New reflash for all 6.4L Jakeman68 6.4L Power Stroke Diesel 30 10-22-2008 02:41 PM
Custom tune ecu on V10 Under Pressure Computer Chips & Tuners 11 06-02-2008 08:08 PM
Programming chip with a laptop shughe40 1999 to 2016 Super Duty 5 06-01-2007 01:34 PM
Ecu/ecm Programing Nasty Computer Chips & Tuners 2 07-24-2003 08:21 AM
Tags
54, chip, ecm, ecu, f150, ford, fords, laptop, program, programing, programming, software, trucks, tuner, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
