1978 F250: Swap Dana 60 for Sterling 10.25?
Just curious as to what problems I may run into if I decide to swap in a 10.25. My current D60 should do me fine, I just want an easier time to get to the drum brakes Also, what years can I find a 10.25 with out a ABS sensor hole, if any year was offered with out one.
I believe a pre 93 10.25" would be the area you would want to look for to have a case without the hole... But i dont think its really a big deal. I just put a 10.5" from a 01 pooperduty in mine with the sensor still in it, no tone ring, but still, no worries. Im not tooooo sure how long the snout is on that D60 you have, but i know when you start swapping out the smaller diffs, you have to shorten the drive shaft for sure, I did with the 9" i had in my 79.
Brian
Brian
I think the U-Joints stayed the same on the heavy duty axle with the exception of switching between gas and diesel powered axles. The original 10.25 axle that came on my truck stock had U-bolts to hold the U-joint in place, now the truck has a newer 10.25 with lim. slip and it must have been off a diesel because it has the strap style to hold the U-joint in place and I had to get a conversion joint to hold it all together correctly.
Mike
Mike
TURBO
09-29-2016 12:44 AM
TheTowingCowboy
03-18-2011 12:40 PM
