Flexplate E4OD
Flexplate E4OD
Ok, purchased a 1995 7.3 with an E4OD, around a 75,000. Standard cab, F250 4X4 a couple years ago. Ran good for about 30,000, just a turbo oil leak and a cam sensor.
This truck has had three flexplate installed and they cracked in less than 3000 miles. The trans was rebuild, new flexplate, new torque converter, ran less than 3000 miles, cracked the flexplate.
Took it to ford, had a ford rebiult trans and a new flex plate, 5000 and the same thing....
Engine endplay is fine, oil pressure and everything else looks fine.
Any ideas?
Any ideas?
There was a TSB put out about this problem. Main cause was machining of the rear gear cover (machined cast aluminum part between engine and trans). The bad covers were machined off parallel and caused extra load on the flexplate. The fix was to change the gear cover AND the following p[arts (since they may be damaged after flexplate failure): crank spacer, flexplate reinforcing plate, crank bolts. Since your vehicle has 75,000 miles omn it, then it is possible that the gear cover is OK. These failures are usually low mileage. To tell if the gear cover is OK or not, remove it and use micrometers to measure the thickness of the cover all the way around. The measurements should all be well within .010" of each other. I've seen bad ones which were any where from .015" to .118" different. If your's measures OK, then I suspect that the other parts (crank spacer) was damaged during one of the failures. The flexplate for the 7.3 is pretty durable and doesn't really have any warranty history other than special causes like the gear cover issue.
