blown head gasket - Ford Truck Enthusiasts Forums
blown head gasket
Old 07-08-2005, 09:01 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
blown head gasket
ok, so after i get back monday after being gone for 2 weeks, i drive my ranger a little bit, i got about 100-200 miles or so and it starts acting funny, it started by popping the pcv valve out a couple of times, then i started getting white smoke in the cab, then when i went to leave town, my dad was following me, he said that it had white smoke coming out from the drivers side under the cab, and it was really gutless, 45 was about all it could muster, was almost able to reach 50. my dad says that this is a bad headgasket, now i regret tearing into the engine without running a compression test becauseeverything seemed fine except that the headbolts were cranked on way more than what they should be, and the front of the #4 piston looked like the ring land was ate away from detonation. but there is no groove whatsoever in the cylinder wall.so now im kinda lost as to what happened.
Old 07-13-2005, 08:40 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
I'd check for cracks in the combustion chamber. Look VERY closely and you may find a hairline crack that opens up when heated.
tom
Old 07-14-2005, 04:30 PM
88treadbrite_150_4spd 88treadbrite_150_4spd is offline
88treadbrite_150_4spd is starting off with a positive reputation.
most likely a cracked or warped head
Old 07-14-2005, 09:43 PM
im gonna check it for being warped, and im gonna do the best i can for cracks w/o magnafluxin it. but i think that i found the problem. on the intake gasket it looks like it had been cut beside the waterports and it shows where it had been leaking water into the intake.which also explains why there was no water in the oil and no oil in what little water there was.
Old 07-16-2005, 02:31 AM
that most definetly could be the cause
Old 07-17-2005, 04:37 AM
whats strangest is that napa has taken over a week to get my gaskets in...
Very Hard Start when Cold RedDevil460 6.0L Power Stroke Diesel 15 09-20-2013 08:52 PM
White smoke issues/coolant smell elkohcaliente63 1999 to 2016 Super Duty 6 03-16-2011 12:43 AM
v10 smokes sanders46 1999 to 2016 Super Duty 10 01-31-2011 09:02 AM
Semi built 351m need help figuring out whats wrong. 77flareside 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-27-2010 10:53 PM
running to rich, whats wrong? PaYneR 1999 - 2003 7.3L Power Stroke Diesel 48 01-29-2009 06:08 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1984, 1985, 300, 50, blown, bronco, f150, ford, full, gasket, head, headgasket, size, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
