1956 f100 Lowering Rear Leaf Springs - Ford Truck Enthusiasts Forums
Old 07-07-2005, 05:43 PM
ZZMAXX25's Avatar
ZZMAXX25 ZZMAXX25 is offline
ZZMAXX25 is starting off with a positive reputation.
I have been looking through old threads for information on lowering the rear suspension of a 1956 f100 Panel by removing spring leafs. Would someone who has completed their rear suspension please let me know what springs they removed and if the ride is good?
Thanks
Maxx
Old 07-07-2005, 08:56 PM
ferguson777's Avatar
ferguson777 ferguson777 is offline
ferguson777 is gaining momentum as a positive member of FTE.
Old 07-07-2005, 10:23 PM
imlowr2's Avatar
imlowr2 imlowr2 is offline
imlowr2 is gaining momentum as a positive member of FTE.
In addition to the great post from ferguson, I'm running four leafs on my truck and I raised the front hanger to the top of the frame rails. Gave me an addition inch. Truck rides real nice.
Old 07-08-2005, 12:25 PM
ZZMAXX25's Avatar
Rear Suspension Lowering
IMLOWR2: I like the looks of your trucks suspension stance and height. Which springs did you keep? Where did you get your spring/shock mounting hardware? Thanks for the info.
Old 07-08-2005, 02:39 PM
54 gene 54 gene is offline
54 gene is starting off with a positive reputation.
Go to www.midfifty.com they have all the info and pictures in there catolog hope it is of a help to you.
Old 07-08-2005, 02:54 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
ZZ: Most people just remove every other spring, starting on the bottom, (of course). But on mine, I kept the four longest ones and removed the three shortest. This was on the advice of the local spring company. I have also installed the plastic liners, ground off the sharp edges on the mating surfaces and applied a thin coat of axle grease. The ride is better, but still a little too firm. The delima I have is that if I remove another spring then the rear will be too low. So I may have the three longest springs re-arced and then go with only those. Of course, by removing springs you realize that you are severely limiting your carrying capacity. Good luck, Jag
Old 07-08-2005, 04:00 PM
imlowr2's Avatar
ZZ- Thanks for the compliment. Actually I did just like Jag said. I originally had 6 leafs on the rear. The hangers are all stock. I removed the 2nd and fourth spring starting from the bottom. That gave me about 1" drop. Then I also raised the front hanger. You have remove the rivots and simply move it up by drilling holes higher up on the frame. That gave me another 1". That's all I did for the rear. I'm running four leafs in the rear and that give me a pretty nice ride. Not spongy or too firm. Hope this helps..
Old 07-10-2005, 09:36 PM
e william's Avatar
e william e william is offline
e william is starting off with a positive reputation.
I used a 2" drop hanger from Mid-Fifties (actually gave me 1 1\2" drop) along with relocating the forward rear hanger 1 1\2" upwards on the frame...this kept the rear u-joint angle just as it was so there was no need for agle shims or rewelding the spring perches....I also left all the springs, knowing it would be stiffer...but I need that to run the 15 x 10's that will be peeking out of the fender edge.
good luck with your drop. Ed
ps...used a mono reverse-eye in front and got 4 7\8" drop.
Old 07-11-2005, 12:13 AM
black58's Avatar
black58 black58 is offline
black58 is starting off with a positive reputation.
Hows the ride with the drop springs? I've wanted to do that for a while, but haven't been able to talk to anyone about it. John
Old 07-11-2005, 01:18 AM
e william's Avatar
John, As for me..I dont know how the ride is yet. I still have parts scattered all over the garage. Plan to do the engine build up this week and put it back on the frame. My small oil leak turned into a frame-up.
Between the supposed softer ride of the mono spring and the toyota pwr. steering I installed it should be pretty sweet! Ed
Old 07-11-2005, 02:29 PM
Jag Red 54's Avatar
Lightbulb
This thread got me to wondering about my setup and the less than smooth ride. I checked it out again and made a startling discovery. As I have been removing the springs for the softer ride, the gradual lowering has put my shocks at there useful limit. So, slow riding was not too bad, but if I hit a bump at speed then the shocks were bottoming out. I reinstalled the upper mount to the highest hole on the cross member and the ride is much better. This is very embarrasing to put out in puiblic, but maybe it will help somebody else. Jag
Old 07-11-2005, 03:18 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack has a good reputation on FTE.Randy Jack has a good reputation on FTE.
Jag -
Thank you for your humility. It serves us all well.
Now...you actually have different holes to mount to? "Useful" travel limit? What a concept! I consider myself edified.
Old 07-11-2005, 04:26 PM
Jag Red 54's Avatar
Yea Randy, my cross member actually has three holes for the top of the shock to be attached to. For some reason, I had mine in the lowest hole. It must have been something I did three years ago before I started taking out leafsprings. Anyway, I'm glad I won't be having to go to the expense of having the springs re-arced. Jag
Old 07-11-2005, 10:47 PM
ZZMAXX25's Avatar
Thanks for all the great information. I pulled my original rear suspension tonight and temporarily attached my Ford 9 Inch rear under the top spring while I clean and prep my other springs and decide what leafs I will end up using. I had hoped to use my original axel mounting base that has the attachment post for the shock absorber mount. The Ford 9 inch rear is about ¾ of an inch bigger around so I don’t think I will be able to use the original base (u-bolts bow out). I can weld a shock mount to the axle but I would prefer a base mount. Ferguson’s spring life article states “keep 1,3,5,7 and the main leaf”. I have seven original spring leaves, four short and three longer ones that are attached by end retainer hardware for leaf 5,6,and 7. The retainers are riveted to the ends of spring 5 and the bolt height is set for the three leafs. If leaf 6 is not used, do you drill a lower bolt hole in the retainer to avoid the inevitable rattle? Thanks again guys.
Maxx
Old 07-12-2005, 12:04 PM
ZZ,
If you're lining the springs with teflon/poly, it'll probably take up most of the space gained from leaving out leaves.
I know I've had no problem at all with any clatter from mine although the only mileage mine gets is when I roll it out of the garage to do some welding on it, etc......
1956 F 100 Leaf Springs Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-10-2014 08:32 PM
Leaf Spings Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-05-2014 09:53 PM
1956 F100- 1956 Mercury 100 1956in1956 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-15-2013 12:08 PM
73 F100, swapping F-250 rear leaf springs hoss73ford 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-20-2013 12:48 PM
Rear Leaf Spring Suspension SportCustomWalt 1967 - 1972 F-100 & Larger F-Series Trucks 0 06-04-2007 08:54 PM
Tags
1956, 1967, f100, fifties, ford, leaf, lowering, mid, rear, short, smooth, spings, spring, springs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
