2.3L flooding - Ford Truck Enthusiasts Forums
2.3L flooding
Old 07-06-2005, 11:50 AM
freejay freejay is offline
freejay is gaining momentum as a positive member of FTE.
2.3L flooding
My g/f has a 87 tempo with the 2.3L CFI. The car floods itself so bad when cranking that it won't even start. It also floods itself out when idling sometimes. This condition comes and goes so it is difficult to diagnose. We hooked a vacuum pump to the MAP sensor and the injector would quit flooding when we pumped it up to about 10 inches Hg. The port on the manifold where the MAP is connected to is only pulling about 3 inches when cranking. The car pulls 15 inches Hg when it is running. I tried replacing the MAP sensor and it didn't fix the problem. I disconnected the battery for a few minutes the other day, but I read somewhere that you have to disconnect it for 10 minutes or so before the computer will reset itself. The car runs pretty good other than this flooding issue so I would like to get it figured out. Any ideas??
P.S. I looked all over the net before posting here and it seems like everybody here is the most knowledgeable so that is why I'm asking car questions in a truck forum.
Story time! Holley Carb and/or Fuel Pump issue DrainBramage Fuel Injection, Carburetion & Fuel System 7 11-18-2011 01:49 AM
starting problem ponypower 1987 - 1996 F150 & Larger F-Series Trucks 3 04-03-2011 03:22 PM
Downunder,,,,,, literally,,,,, Floods in Australia RottenRon 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-17-2011 09:28 AM
Why does my engine always flood?! nothercrash 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-22-2010 11:12 PM
Help! '86 2.3 Ranger broke down Woodtroll 4 Cylinder Engines 10 05-03-2007 09:49 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2005, 23, 23l, 87, cfi, engine, f150, flooded, flooding, floods, ford, lt, map, randomly, sensor, tempo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
