Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-30-2002, 03:04 PM
sGreuel is starting off with a positive reputation.
73F100 4X4 drum to disk?
I would like to know what years of front disk brake systems would fit on my '73 F100 4WD. Is it only up to '79? I've found numerous 80&up 5-lug IFS's in the salvages, but don't know if any of those systems(rotors, hubs, spindles,etc.) will fit. What all parts do I need?
I don't climb rocks, but I do seriously work this truck. Stopping better with heavy loads would be nice. I just heard some metal up front so now's the time to update if possible.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-30-2002, 09:48 PM
dinosaurfan is starting off with a positive reputation.
I think the stuff you need will be under a 73- 79 truck. All of the 67-72 trucks that I have seen had drums up front, with the discs starting in 73. My '71 4wd has a drum brake D44 axle, with open knuckles. I purchased a complete front axle from a 1976 F150, it also has the open knuckles, but with disk brakes. The frame of the truck got wider in 73, and the axle tubes did as well. But the ball joints were the same part #, and the disc brake ends look like they will fit, but I waiting to hear that metallic sound before I try them on. DF
  #3 (permalink)
Old 01-08-2003, 12:33 AM
Thanks DF. So you say the spindles ARE different between drum & disc systems. I sure wish I could use one of those 80's front diff's ends, they're everywhere I look. I guess I'll keep scouring the salvages for 74?-79 axle. So, I wonder when the half ton 4WD's started getting disc's? Probably the next one in line after my '73.:-( Ha, Ha!!
DF, Do you also have the power assisting slave cylinder type whatchamacallit booster whopper steering system? That's something else I'd like to remedy, If anyone has any suggestions! Or, should I post that as another question? I'm new here!
  #4 (permalink)
Old 01-08-2003, 12:47 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #5 (permalink)
Old 02-06-2003, 11:30 AM
bphillips777 is starting off with a positive reputation.
The outers you are looking for started in seventy seven, they also started to figure out what real power steering was then. I have a 75' f-100 and it has drums I would go the disc route too but I am going to a 3/4 ton running gear under the old half ton in a few weeks.
  #6 (permalink)
Old 02-06-2003, 11:34 AM
okiebronco's Avatar
okiebronco is starting off with a positive reputation.
as far as the master cylinder and vacuum booster goes alot of people use ones off a 3/4 ton. i dont remember why unless its because they have a bigger piston in the master cylinder
__________________
76 bronco- 5 1/2 inch deaver springs,extended radius arms, 3 core triple pass radiator,f250 shock towers,rear inboard shock hoops,full roll cage,stc soft top,36/12.50/15 tsl's,302/c4/d20.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
