Cabin Air Filter - 2001 F-150 - Ford Truck Enthusiasts Forums
Old 07-05-2005, 10:22 PM
rosco_p_coltrane's Avatar
rosco_p_coltrane rosco_p_coltrane is offline
rosco_p_coltrane is starting off with a positive reputation.
Can anyone tell me where the location of the cabin air filter is on a 2001 F-150? Would just like to know before I have to start tearing into a bunch of different areas. Thanks, Chris.
Old 07-05-2005, 11:40 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
If it has one, Which I doubt, it is accessed thru the passenger side kick panel.
Old 07-05-2005, 11:55 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
I can actually answer this one for you. I run a Texaco Xpress Lube and for YEARS, yes YEARS, looked and looked and looked for an F-150/Expediton etc with a factory installed cabin air filter and NEVER found one. Ive owned several 97-03 F-150s and have always wanted a cabin filter in my truck and about two months ago I finally got one.
I actually stock the filter - GKI number CF1007 available from Oreillys. Ford supposively sells a kit for like $80 with the filter and instructions - well all you need is a filter and you can install a cabin air filter in any 97+ F-150 in about ten minutes.
Under the passenger side dash about where your feet would be, you will see a "door like" cutout in the bottom of the heater box. It is about a foot long and about an inch and a half wide with a little "runner" around the sides. Turns out, that plastic is really thin and can be cut right through. All you need to do is take either a razor knife or a pocket screw driver (BE CAREFUL - I got cut) and run it around the edge of that "door" that is attached to the heater box. When you run it around there, it will cut out and remove the "door" from the heater box. Take the cabin filter with the tab down and stuff it in the hole and whala - you now have a cabin air filter. The filter with the pull tab serves as the door - no additional parts needed. A cabin filter, this knowledge, and about 10 minutes.
Good luck! BTW, if you buy the cabin filter, it has a picture of the bottom of the dash showing you the "door" but they actually say it is a pop out real easy to do sort of thing. This was something that took some figuring out.
Old 07-06-2005, 01:07 AM
Thanks for the info! I was at the parts store getting stuff for an oil change and the clerk asked me if I wanted a cabin air filter. I bought it and couldn't figure out where the damn thing went. You learn somthing new everyday. Thanks again, Chris.
Old 07-06-2005, 04:00 PM
Patatoe1's Avatar
Patatoe1 Patatoe1 is offline
Patatoe1 is starting off with a positive reputation.
What does the air filter do? Besides for filtering air? Is there any perks to installing one?
Old 07-06-2005, 05:21 PM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
That's interesting CCORAM! I also wanted a cabin air filter for my 2001 F150, and finally found the Ford kit as surplus stock on eBay. Besides an aluminum cut-out guide, it also has a rather convoluted metal frame, which the filter sets up into, and that door which is held onto the frame with 6 little screws (PIA!). But, yeah, the filter is fairly tight and might seal by itself. Does yours seal at the bottom? Maybe one could just cut the opening in the plastic a little smaller, or maybe put some rope caulk around the bottom. Sounds like I could have saved the time and money.
For those who asked; the cabin air filter is a kinda' high end item now supplied in many cars (my Buick Park Ave has one), which, like your furnace filter, attempts to remove dirt, dust, and pollen from the interior air. I don't know how successful it could be given how often the doors and windows are open, but I do know that mine accumulates a lot of dirt after six months. Hopefully, that helps an allergy at least somewhat.
Old 07-06-2005, 11:12 PM
Yeah the filter seals perfect at the bottom. No air getting out at all = plus with the pull tab on the bottom of the filter it comes right out for the next replacement. I just cut the hole the size of the indention around the door and it worked perfect.
2001 F150 Cabin Air Filter? Redfish5 Cooling, Heating, Ventilation & A/C 3 03-07-2014 11:20 AM
Filter derek4343 2009 - 2014 F150 6 01-06-2014 11:48 AM
Cabin air filter 2001 F250 diesel crew cab engdccs 1999 to 2016 Super Duty 15 07-02-2008 03:49 PM
Cabin Air Filter R@r PAPA912 Cooling, Heating, Ventilation & A/C 2 09-13-2006 12:04 PM
Cabin air filter in 2001 super duty f350?? Rintin69 1999 to 2016 Super Duty 1 01-14-2004 07:49 PM
Tags
150, 2001, air, cab, cabin, cabine, change, f150, filter, finde, fiter, ford, location, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
