03 superduty trailer wiring problem
I accidentally shorted my trailer wiring on my 03 superduty.Now I don't have any power to the trailer lights.(right and left blinkers still work).I am sure I must have blown a fuse.The trailer wiring must have different fuses since the tail lights on the truck still work.I looked under the dash at that fusepanel and found one 20A fuse blown.Replaced that but still no power to the trailer lights.Is there another fuse somewhere?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
I have heard that there is another box near the main fuse panel, haven't verified it.
If ya hang on till later, some of the guys that yank toy trailers will be on after work and will be able to help. I know I've seen it on here but couldn't find it with a search.
EDIT:
See if this thread helps...
https://www.ford-trucks.com/forums/s...er+lights+fuse
EDIT:
UPDATE on 03 superduty trailer wiring problem
Found this thread here where I can download factory manuals.This gave me the fuse locations and description.On a 03 superduty there is NO fusebox under the hood.All the fuses are behind the large panel under the steeringwheel.I then found a second fuse(20A) #38 blown.Replaced it and all my lights work again!
Thanks for all the replies,hope to return the favor someday.
Pete
Pete
Michael Sharps
Electrical Systems/Wiring
09-29-2011 06:38 PM
