2005 E-250 van 11,500 miles 4.6, got towed away this morning with a DEATH noise in the engine, this is used for a/c service, city mile been using 5-20!
My dad's E-250 Extended Turtle Top Limo Van has about 150k and still going strong. Although it uses some oil(Mobil 1 10w30) between changes. Its very reliable and he runs it pretty hard sometimes.
My 97 Expedition XLT work truck just turned 500,000 kms (310,685 miles).
The only babying it gets is full synthetic oil changes (Castrol)...... my
workhorse just needs "water". It's a 4.6L.
My 98 F150 4.6L extended cab with a 8ft box has 282,000 Kil. 175,000miles. Knock on wood. Oil changes every 3 to 4 thousand K and Tranny changes 50,000 K. the drivers door is rusting out on the bottom and it has the good old pistonslap for about 5 minutes on cold start ups.
175,000 miles. See, I knew that there was no need to worry about the piston slap, it is annoying, but doesn't hurt anything, just proves that the piston skirts were a little short allowing the pistons to slightly wobble in the cylinders until they heat up and expand.
