Pissed off at wife!!!!!!!
Short story. I had a gas jug with some water in it for a friends radiator when he was broke down. It was stored in the back of the house. It had about 3 to 4 gallons of water in it. My wife had to use my truck while I was at work. As always my f250 2wd 1973 was on empty. So somehow she finds my gas jug (water jug). And guess what? Yep! She said it smelled like gas! Damn that took 2 days to drain the tank and three fuel filters. And it still runs like a chevy!!! It backfires at low to mid rpms repeatedly. Higher rpms its ok. 1st to 2nd almost stalls and sounds like a machine gun. Please help
Thanks for the reply putt and bear. Would all that water have any effect on my carb. ie(jets, power valve, or float needle). I put about a gallon of isopropyl alcohol over a 1 month period. It backfires like crazy at lower to mid rpm. I thought the water was gone, I guess not. Help please
You might have water in the carb bowl... where the float sits. Otherwise, I can't think of anything where water would collect and cause problems. Maybe the fuel pump, but I don't see it harboring any water internally...
I actually agree with you - even though it was not in the "proper" container, she should have asked before *****-nilly using something that only you knew about. Perhaps Of course, it begs the question of WHY not go to the gas station? Even if it's 40 miles away ...
art k.
art k.
The trouble with water in a fuel system (something I have a lot of experience with having been a marine mechanic) is that the pot metal in carbs and the steel in tanks corrode very fast and then the only thing that works is a teardown. At least you used isopropyl and not methonal or ethonal (very corossive on their own). The other problem is the water can ruin your spark plugs and cause the problem you are discribing.
Originally Posted by 2tone73
Short story. I had a gas jug with some water in it. So somehow she finds my gas jug (water jug). And guess what? Yep! She said it smelled like gas!
OK back to topic, Bear is right, it takes little time for water to bugger things up. I've also been told that it will move through the fuel system by capillary action. If it made it to the carb, it has worked it's way through the smaller passages. Break out the Chem-Dip and get it over with.
If you bought this off a store shelf instead of a chemical supply place, it is most likely 70-90% alcohol and the rest is WATER. If it was rubbing alcohol it has traces amounts of oil too. FWIW.
I would change the spark plugs and check the compression.
Unless it had big stickers or labels saying WATER your wife is not to blame. At my house the red containers are gas, the refilled anti-freeze jugs are only for radiator water, and emergency drinking water inside the house/car are reused fruit juice bottles.
2tone73 waterlogged!
Thank you all for the replies. Every little bit helps. I experienced some new things with the truck. From one special red light it ran perfect no bogs it hauled ***, for about 2 seconds! Now back to being sluggish. In the morning it runs like crap but when it gets warmed up it feels like its running on 4 cylinders, no power. When I try to hit passing gear it bogs down like its not getting fuel, so I pump the pedal hard and it hits passing gear 1st or 2nd. When it shifts back to 3rd or 2nd its boggy time. Normal driving from stop 1st gear is a little boggy when it shifts to second will not hardly run so I mash the pedal. Higher rpms it seems fine but getting there is another story! "Just send me the bill" For all the help! Thanks
Better reckon with the Mrs. first. Then maybe she'll let you spring the $15 for Chem-Dip and the 10-40 dollars for whatever carb kit you need.
You could try "chemical therapy", but there is not much point in suffering the lousy performance and lousy mileage just to get that much fuel additive through your system.
Keep us posted , Mike
Or as Bear said, corrosion is already taking hold and it's time to clean out the carb...
