what coil springs
what coil springs
i have a 1995 bronco with a 4 inch superlift and im upgradeing to the 6 inch with getting sway bar drop brackets and an add aleaf in the rear. my front end sort of seemed to sag alil already only after about 3-4 months. it does have some more weight thought with a plate steel winch bumper from bronco graveyard and a 12000 mile marker in it. i was wondering if another companys springs would be lil stiffer or would hold up to there size mybe like skyjacker or bds or any other ideas
thanks
thanks
You can put some coil spacers. Cheap and affective.
Get some 8 1/2" coils from bronco grave yard, and put some 3" blocks or some combination of add a leafs and blocks to = about 3"s of lift. The front coils will sag with the weight on it, and maybe sag alittle as they get older. You'll have around 7"s of lift, NOW, would that extra in. hurt???
Other wise, some people will swear that superlift is the best, skjackers the best, etc... , but they all seem to be pretty good quality.
Good luck,
-Matt
Good luck,
-Matt
XLTRat
10-11-2016 10:27 AM
reamer
02-26-2016 02:44 PM
4x4bronco92
07-22-2003 03:30 PM
