PCV/breather hookup with MAF coversion ?
Truck is an 87 F150, 302 EFI, 100k miles on a rebuilt short block
Last fall I converted my truck to MAF and basically made my own K&N intake assembly. Since I no longer had the stock airbox to connect the crankcase breather pipe, I knocked a hole in the side of the intake pipe and connected the breather pipe into that. The hose from the PCV valve is routed to the intake as well, just before the throttle body.
Is this a bad idea? I noticed recently there is smoke coming from the oil fill when I remove the cap, and wondered if the vacuum might have sucked in a gasket somewhere allowing exhaust into the crankcase. Thinking I might be getting blowby, I checked compression on all cylinders, all are between 155 and 170 PSI. I then removed the breather pipe from the intake at idle and lots of smoke came out the breather.
Should I have just put a filter on the breather rather than routing it to the intake?
Brian
Brian
As long as the breather going to the intake before the throttle body sees filtered air, you're all set.
If it taps in downstreem of the airbox, it's already filtered air (MAF application). The speed density system has the PCV breather going over to the airbox and has it's own filter because it taps in upstream of the engine's air filter.
The PCV hose doesn't originally go to the vacuum tree. I guess you could put it to the vacuum tree but I don't know how because there isn't an available opening on the tree for it.
If it were me, I'd take the upper intake off, and tap a hole in the bottom of it and screw in a barb fitting so I could attach the hose there. My edelbrock intake came tapped and threaded so I just put the barb in there and hooked it up. It also had the hole in the back for the stock PCV location, I blocked that with a plug.
Originally Posted by MustangGT221
My MAF has the little Y where it splits from 1 tube into 2 tubes before the throttle body, which is where the PCV taps into the system, which yes would be between the MAF sensor and TB.
The breather is currently connected downstream of the air filter but before the MAF.
Sounds like I need to move the PCV to the manifold and move the breather to the connection before the TB, after the MAF of course.
After putting way too much brain power (and some beer) into the whole subject I decided two things:
1. In order for the PCV system to work properly there needs to be more vacuum on the PCV connection than on the breather connection, and
2. I don't know how there would be such a difference in vacuum, or pressure, when both are connected to the same pipe before the throttle body.
So I connected the PCV to the manifold tree and the breather pipe to the y-pipe after the MAF sensor. Now there is no smoke with the cap removed, smoother idle, and for some reason higher oil pressure(yes I have a real gauge).
you guys knew all that right?
Later
Brian
Later
Brian
Later
Brian
Later
Brian
The gauge was reading 15-20PSI at idle when warm, now reads around 25PSI. At about 2000RPM it was reading 40PSI now almost 50PSI.
I noticed it last night after reconnecting everything, and today coming to work. I asked a few people here at work, they have no explanation other than slightly faster and smoother idle.
Brian
Brian
