How to wire in stock factory options.
#61
Hehehehehe
Yeah, I guess that's more than just the pad, huh?
But, it's through projects like that where I learn those things.
Pages 10 & 11 here:
https://www.ford-trucks.com/forums/1...ml#post9844495
Pages 10 & 11 here:
#64
This may have already been answered but 5 pages is alot to read through
My '80 F250 XLT Ranger has manual windows and door locks and i would like to convert them to power while i have the whole thing apart. If I were to find a nice set of panels at the wrecking yard, what all would i need to grab in order to make the swap?
Thanks
JM
Thanks
JM
#66
Now -how- did you get the screws out where the dash speaker bracket mounts to the front of the dash??? Both my truck and the donor truck I got my dash from had those screws seized up solid! lol I had to get "creative" with both of em...
#67
on
Thanks
JM
Thanks
JM
The Fuse panels are wired different as well between 1980 and 1981-1986. Here are the power distribution wiring diagrams for the 1980, then the 1981-1983.
1980 Power distribution:
http://i447.photobucket.com/albums/q...ring81-1-2.jpg
1981-1983 Power Distribution:
http://i447.photobucket.com/albums/q...l/scan0010.jpg
1981-1986 power windows
http://i447.photobucket.com/albums/q...ciel/001-1.jpg
1981-1986 Electric Mirrors
http://i447.photobucket.com/albums/q...rordiagram.jpg
#69
Well, the 1980 is the only year that didn't have power windows as an option, so it would take some work. If you had a 1981-1986 all you would need is the switches, wires, motors, regulators, and circut breakers to plug into your fuse panel. With the 1980, running a power feed directly from the battery via a fuseable link would probably work the best, then finding a way to hook up the circut breakers, or get aftermarket ones if avaliable.
#70
on
It may or may not have the holes in the doors. That I do not know. Most likely not, looking at Fordzilla80's, 1980 doors with the panels removed, posted in this same thread. The doors that originally came with slide locks, 1980-1981 do not have the holes for the "vertical locks" and ***** either.
As for the wiring, you could change your complete underdash harness for a 1981-1982.
Anything newer than that and you will have problems connecting components. You will have to match the main wiring harness to the charging system instrumentation that is in your truck now. Either full gauges ammeter and oil gauges, or altenator and oil warning lamps.
However, you will need to change out the headlamp switch for one for a 1981-1986, and change the instrument cluster, and instrument cluster bezel for one for a 1981-1986, or rewire the instrument cluster connector, as the printed circut on the 1980 cluster is different.
You will also have to change the slide locks to the "vertical locks" type. And as a concequence you will have to change door panels, as removing the slide locks will give you a large hole in the panel. Or just have the power windows without power door locks.
Seems like a lot of work...
#71
#72
#73
#75
82F1507.5
34
03-14-2019 02:11 PM
Montync
03-02-2017 12:33 PM
BainbridgeBrewer
12-31-2016 08:38 PM
