Turn Signal Wiring Diagram - Ford Truck Enthusiasts Forums
Old 07-02-2005, 05:41 PM
51dueller's Avatar
51dueller 51dueller is online now
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
Would you guys have a turn signal wiring diagram for a '69 C-750 COE truck?
Old 07-05-2005, 12:23 PM
qman qman is offline
qman is starting off with a positive reputation.
It's pretty easy to figure out which wire does what. Just take and plug things into the harness and try them. In 10-15 minutes you'll have it all figured. Like I put one wire in and tried the turn signals and the horn went off. That told me which wire from the switch was for the turn signals and which in the harness was for the horn.
Old 07-05-2005, 01:07 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
What exactly do you need to know. Sorry I don't have a diagram, but like q mentioned it can be sorted out.
I did post your question over on the ATHS truck forum. Those guys have the bigger trucks and will more likely have some idea where information can be found.
I'll try to keep you posted.
Old 07-06-2005, 03:48 AM
71_4x4_390's Avatar
71_4x4_390 71_4x4_390 is offline
71_4x4_390 is starting off with a positive reputation.
I have the diagrams for 1968, all models. I don't think there would be too many differences. I could scan it for you and email it if you still need it. Just give me a day or two...
Old 07-06-2005, 08:03 PM
gjc12 gjc12 is offline
gjc12 is starting off with a positive reputation.
Unhappy
If someone's got a diagram I'd appreciate a copy too. I just got a '71 F100, and the turn signals only work with the ignition in the accessory position. The previous owner recently replaced the ignition so I'm guessing he may have wired something wrong, but I haven't figured it out yet.
edit: Well I was messing with the ignition, I had pulled the tumbler out and was fiddling with the wiring in the back. Then I heard a "hissss.....POP!" and got that nice smell of burnt wiring. The wiring on the back of the ignition got really hot, especially a thicker yellow one, and of course the truck no longer starts. I then realized I had gone from non working turn signals to a non working truck. ugh.
Old 07-07-2005, 01:26 AM
71_4x4_390's Avatar
I'll bring in the diagrams to work on Friday or Monday, then post the scans in my gallery, I'll post the f100-250, and the c750 or equivalent.
Hope this helps....
Old 07-07-2005, 01:59 PM
A guy here named "jor" just sent me the wiring diagrams for a '67 so I think I'm good to go. Thanks a bunch though 71_4x4_390.
Wiring Problems reasonde Electrical Systems/Wiring 3 12-30-2012 06:23 AM
Wiring Diagram needed idealtrucks 1967 - 1972 F-100 & Larger F-Series Trucks 23 01-23-2011 11:24 AM
1960 f-100 turn signal brockwood Electrical Systems/Wiring 2 06-12-2009 06:50 PM
Turn signal switch? dstruble 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-27-2006 11:11 PM
'65 F100 Horn & Turn Signal Wiring Diagram? 53Merc 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-31-2003 02:48 PM
Tags
1971, 2003, 71, blinker, diagram, explorer, f100, schematic, signal, turn, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
