Splash Pan: To cut or not
on
I have an original splash pan for my '51 M-3. Now should I cut it to clear the front sump of the oil pan on the 302 or should I leave it intact and save it for someone else to use? Out of my three trucks only one had it. I guess if a PO took it off they never bothered to put it back on.
on
Nathan,
I'm not sure if you are refering to the radiator splash pan than goes just in front of the radiator or not, but I cut about two inches off of mine since I was using the six cylinder radiator support holes. I like having it since it also serves as a scoop to force air through the radiator core which should help cooling. I also have a stock 49 F-1 which does not have a spash pan. I guess it was deleted at some point in the past by a PO.
Vern
Vern
on
I figured it was pretty rare to have one. I think I might put it on to be different than everyone else. It's not in perfect shape but it's fixable. After it's been cut I can drain oil without removing it (dual sump oil pan). It should keep water and mud from being splashed on to the front of the engine.
Here's a picture of it:
Here's another thing that seems to disappear on these trucks. The fender splash guards:
My first truck was missing both, second truck had driver side and third truck had the passenger side.
51PanelMan
03-27-2005 07:17 AM
66fairlane390
08-16-2004 04:30 PM
zirok
Computer Chips & Tuners
08-04-2003 04:55 PM
51dueller
10-05-2002 01:26 PM
