rear main leak
rear main leak
Good afternoon all, the new 2000 F150 with a 4.6 has a leak in the rear main. Is this a common problem for thoes engines?? As when I looked at quite a few that were on the lots they all had a rear main leak??
Since I am going to change it is there any thing else I need to change when I pull the tranny and tranfer since I am there (you know other common problems)??
Looks like a bummer to do but is there any tid bits I should know when I do the job or is it the same as any ther vehicle.
Thanks in advance
Lance
Thanks in advance
Lance
Thanks for the info, maybe it's this area CO. any way sounds like a fun way to spend a Saturday, just didn't want to get cought flat pfooted and needing something. I'll look out for that head gasket leak when I looked earlier the only leak was the rear main. a little oil from the valve cover.
Lance
Lance
