1974 f250 blower motor fuse - Ford Truck Enthusiasts Forums
Old 06-28-2005, 06:02 AM
otisinwf otisinwf is offline
otisinwf is starting off with a positive reputation.
is there one that could be blown or something as simple as that? It worked fine all winter for the heater but when I turned it on the other day for the a/c I discovered that it just don't work anymore. (relay or fuse) where could they be?
Old 06-28-2005, 10:57 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
The location of the fuse is in your owners manual.
Old 06-29-2005, 05:08 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Is it the original Fan blower motor for your truck? If so, it's probably time to replace it. I just replaced mine a couple weeks ago. It worked okay during the winter, though noticeably weak. Then when the warm weather came it wouldn't blow at all. When I got it out I could barely move the motor shaft with my hand. That thing was just worn, rusted, and crusted. Not bad, for a 23+ year old motor. Also, my fuse panel below the drivers side dash uses one fuse for both heat and a/c. Mine was labeled from the factory. Yours might be in the same spot as well.
Old 06-29-2005, 09:27 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
its in the fuse panel under the dash on the drivers side its a 30 amp fuse.
Old 06-30-2005, 12:50 AM
thanks guys, I'll check it out in the am. I just havnt had time to mess with it. I'm really just wishin it was simple cause I just put the heater core in march, and now the blower is probably toast.
Trailer lights wont work Dutter 2 1987 - 1996 F150 & Larger F-Series Trucks 2 12-14-2014 11:26 AM
Speedo Stopped Working NEA72 1987 - 1996 F150 & Larger F-Series Trucks 2 11-04-2014 09:10 AM
Replace fuse box?????? Hooie2013 Expedition & Navigator 7 06-26-2013 05:17 PM
98 Expy - Need to Find Fuse for power door locks Jeffro6201 Expedition & Navigator 1 03-26-2005 08:17 AM
Is there a second fuse box in the engine compartment? Beatlez 6.0L Power Stroke Diesel 1 06-18-2004 11:04 AM
Tags
1974, 302, 74, blower, dash, f250, fan, ford, fuse, heater, main, motor, panel, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
