Best oil for 360 FE - Ford Truck Enthusiasts Forums
Best oil for 360 FE
Old 06-27-2005, 01:30 AM
mohavi mohavi is offline
mohavi is starting off with a positive reputation.
Best oil for 360 FE
Whats the best oil to use on a 360 in the summer in arizona?
Old 06-27-2005, 02:32 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
year round use a good diesel rated oil and a motorcraft oil filter or a wix i run 10w30 diesel oil year round in mine
Old 06-29-2005, 07:05 PM
78fordf-1504WD 78fordf-1504WD is offline
78fordf-1504WD is starting off with a positive reputation.
Rotella is probably the best oil to use either 10w30 or 10w40, motorcraft filter, and here in Northeast Georgia we have this stuff called HIGH TACH that we use in all our vehicles 16oz. every oil change then fill the rest w/ oil the high tach got us 1 mpg more
Proper oil for 360/390 Brock_Samson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 12-22-2015 09:37 AM
what oil should i run breedo99 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-14-2012 09:19 PM
360 question White76 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-10-2011 12:46 PM
360/390 engine Kalve FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 23 10-12-2009 07:01 AM
What is the best oil additive for an older engine. unioncreek FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 11-14-2001 01:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
