Catalytic Converter failure? - Ford Truck Enthusiasts Forums
Old 06-26-2005, 05:51 PM
llee llee is offline
llee is starting off with a positive reputation.
Question Catalytic Converter failure?
92 explorer 4.0 4wd 220,000 mi
This past Tuesday I finished replacing the lifters(new lifters, rocker arms, pushrods, valve stem seals, etc) & on my truck. In the process of putting it back together I cut one of the orings for a fuel injector. It ran ok for a day or so bt then the pressure caused it to fail. It started spraying gas everywhere(several gallons worth in maybe a minute or so).
After replacing all the orings on the fuel injectors the truck ran great. Friday on my way home I went from crusing at 45 to 25 very quickly. the check engine light came on at the same time.
I stoped and opened the hood. The engine sounded normal. As I walked along the passanger side it sounded like there was a potato(e) in the exhaust.
I limped home the last few miles.
Saturday I was turning the truck around to take a look at it properly. Everything was fine. Ran up and down the street a few miles with no problems. So I got braver. Made it about 5 minutes before the same thing happened again.
I am thinking that after 13 years and 220k miles the converter has given up the ghost. Once it gets hot it clogs up (possibly also caused from a lot of fuel dumping into the engine from the failed oring?)
Before I just go and buy a new converter & exhaust system(a cat back sytem was my much needed next project for this anyway) I wanted to check and see if it is the converter. (I have never had one go bed beforeso I dont really know the symtoms)
Thanks
Les
Old 06-26-2005, 06:58 PM
don96exp don96exp is offline
don96exp is starting off with a positive reputation.
I had a bad convertoer on one of my cars and it would'nt go faster than 40mph. With 220k miles that's not bad.
Old 06-27-2005, 09:16 AM
FloatJ FloatJ is offline
FloatJ is starting off with a positive reputation.
I had one go bad on a previous car as well. The symptoms sound exactly the same. Good luck.
Old 06-27-2005, 05:50 PM
Jharger Jharger is offline
Jharger is starting off with a positive reputation.
Check your code first. The PCM wants to tell you something.
A bad cat can do what you describe. The honeycombs on the inside physically break into chunks and when they turn sideways, gases don't go through them to well. My old VW Jetta did this and it bucked like a bronco for about 20 seconds, slowed down to a crawl, I put it in nuetral and blew out the motor, then it was fine. Good thing too as I was in the middle of a 3 mi long bridge with no emergency parking lane.
But there are other things that can do this, conceivably a MAF meter, IAC valve, bad coil - who knows? Go to this web page for a list of codes. If it is the cat, a O2 code might occur since you sensor is just upstream of the cat.
http://fordfuelinjection.com/?p=1
Power issues, please help troubleshoot The Hooligan 1997-2006 Expedition & Navigator 5 11-29-2016 01:33 PM
Intermittent loss of power question JHG88F350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-05-2016 10:50 AM
cant fix failing bubble test Adam Callan 6.0L Power Stroke Diesel 29 01-31-2016 04:40 PM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 10:29 AM
White smoke caused by ccv blockage? jeffreyt 1999 - 2003 7.3L Power Stroke Diesel 11 10-18-2012 07:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
