Rear wiper has quit
Rear wiper has quit
Hey!
Our 2000 Expy. E.B. has quit wiping the rear window. Washer still squirts, and if it's real quiet or I'm right by the door when it's on, I can hear a very quiet "bop.....bop.....bop" like something in there is trying to work on the intermittant time cycle, but the arm doesn't try to move.
I'm thinking there is an electrical contact problem somewhere in the system that keeps it from coming on when the window is up, but I really have no idea.
It was off-and-on for a while, sometimes it would work again if we opened and closed the window or door firmly, but now ... nothing.
Any thoughts?
Thanks!
-Sam
Any thoughts?
Thanks!
-Sam
Do a search on rear wiper, there was a recent topic covering this about a month or two ago - https://www.ford-trucks.com/forums/s...d.php?t=335705 I had the same problem. Put the wiper on and shake it around - that's what you were doing when you closed the window or door. First time I tried that it came on immediately. Next time it took a lot of shaking to get it going. It's been working on its own since. I expect the problem to return, not sure what the cure is.
Hey!
I've tried the wiggling thing but I think we're beyond that, now. Can't get it to come on at all.
I thought about the simple binding/wear issue, but there is NO movement transferred to the arm at all when the switch is on. It definately sounds like a relay is closing, or maybe a small electrical part is operating, but the wiper motor isn't energizing. It's not "trying" to go. Like it's completely disconnected.
I'll have to take it apart and see what's up.
Thanks!
-Sam
Thanks!
-Sam
I've got the same issue. I haven't tried fixing it yet, but I remember someone saying it could be a relay for the one direction. The thumping sound is the other relay pushing the wiper arm back again (only it never moved). It was something like that anyway.
Let us know what fixes it.
Thanks,
Sam
Thanks,
Sam
Rear wiper fix (if the motor is not burned out)
Just thought I would share my rear wiper story after seeing the thread.
My rear wiper on 2003 Expy quit working (Or rather, I noticed it quit working) a couple of months ago. Took it to dealer for oil change etc, and asked them to look at the rear wiper too. They said that the nut cap had cracked which allowed moisture into the mechinism which caused it to sieze and burn out the motor.... and it is $500 to replace (no repair available).... oh yea, and they had none in stock and would have to order it.
Well, since I mostly drive forward :-) , I declined their kind offer to fix it. I saw the thread on the wiper problem today, and decided to take a closer look at it myself. First of all, it took me all of about 3 seconds to determine that the wiper moter WAS NOT burned out. This I did by simply opening the rear glass and turning on the wiper (you can see the motor cam turning in the door)... So much for the competancy (or perhaps honesty?) of the dealer.
Next I confirmed that the wiper shaft was siezed. so I took the mechanism off of the glass, disassembled it, cleaned it and remounted it.... and it works like a champ.
Good luck all!
Good luck all!
6CylBill
11-18-2008 07:36 AM
cap_nut
12-14-2007 06:06 AM
