You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I live in Boise and have been looking for a PSD. Unfortunately, the prices here are completely ridiculous compared to other places. I look online and this State Street Truck Stop in Sandy, UT keeps coming up with what seem to be decent rigs.
Anyone ever hear anything about them?? I'd hate to make the trip just to be taken for a ride.
I bought my truck through them. I doubt I would do business with them again. Somewhat pricey, and the more I looked and the longer I have had the truck the more things I find wrong with it. But they had the truck I wanted when I wanted it so...
__________________
Mike W.
'12 F150 FX4 5.0 Shortbed SCrew
'07 Fusion SEL
I don't have direct experience with them, but my buddy bought his truck from them. They are pretty pricey, and have the typical used car dealership mentality. If you are an educated buyer, and can protect yourself, they are no better/worse, than any other used car dealership. I also noticed that most of their vehicles have high miles.
mjwhip2- was there anything seriously wrong with your truck?? Like they mislead or hid from you in a shady way?
Yeah Zane, they do have high miles a lot of times. BUT, most of the PSDs you come across for sale do. I am looking in the 95-97 range and they all seem to be that way. If you think pickins are bad there, come to Boise. LOL.
Thanks for the info guys. I wondered if I would get ANY responses.
No they didn't neccessarily try to hide things but... about 4 months after getting the truck tranny took a dump (only had 1 mo guarantee/warranty from State street).
Found a sticking caliper within a week (would've cost more to drive to them than to fix it myself) Their "expert" mechanic tried to install a new stereo for me, since the original was hammered, took him around 3 hours (I was at the dealership waiting) still couldn't get it working, I said screw it and installed it myself at home only to find the "new" radio had a blown channel.
When I was in their "shop" I saw hundreds of body lift boxes. Seems like just about every truck they get in gets a body lift thrown on. I personally hate body lifts.
In their defense, I did get a 97 F250 Crewcab PSD with 51k miles and a D60 front end for a somewhat reasonable price.
If you do decide to get something from them just make sure you double/triple check everything.
If I only knew then what I know now...(it was my first PSD and I really wanted the truck so I overlooked a lot of things I shouldn't have)
__________________
Mike W.
'07 Fusion SEL
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
__________________
Mike W.
'07 Fusion SEL
I have bought 3 trucks from state street truck and have allways been treated great. If you do any shopping on line, I have allways found them to be very well priced.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
