4" lift, 2" body lift???
Hey everyone-
I'm looking at getting a 4inch lift for my 90 Bronco then adding a 2inch body lift. I have heard that with a body lift the bumpers stay the same height and it looks kinda weird, anyway to fix that or do you think with just the 2inch body lift it wont make much of a difference? Thanks for any help!
With a body lift there will be a gap between the bumpers and body. The bumper mounts can be reworked to raise them if you have access to a welder of if being done by a decent shop they can do it. You can also have a piece of alum diamond plate cut to fill the gap which prob would be cheaper if your having it done. Another point of concern is the fan shroud. It will move with the body but your fan thats attached to the motor will not. The easy way out is cutting the shroud.
I've heard people have to lengthen stering linkage, brake lines(of course) and the list went, on. BUT I have no personal experience doing a body lift, so if oldblueford, says he just lengthend the (-) battary cable, then that might be it for, broncos, just trying to keep you out of alot of hidden cost I have heard of on other vehicals.
-Matt
-Matt
just go 6" the lifts cost the same . with a body lift you have to lengthen your shift linkage by cutting a adding . can you weld? then of course everything else mentioned above. im hesitant by oldblue's comments about only doing the neg cable. either his had a body lift prior or something. because everyone that i know has always need to do a bunch of stuff.
I did have to weld the shift linkage, but the price of $100 for the kit and my labor was way cheaper than a $1000.00 6" suspension. But other than that I have had no problems except for the bumper gaps. I know that some brackets can raise the bumper but they leave it unfunctional as a bumper. I feel your best bet would be a suspension lift if you have the money. I think a 6" is the way you should go.
Mark
Mark
Spot weld the bumber
My '86 has a 6" suspension lift and a 3" body lift running 38"BFGs. When mine was lifted, the bumper bracket was un bolted from the frame, adjusted to the right height and welded back to the frame. The bolt holes of course didn't line up, but who cares? If I ever change bumbers, I'll just unbolt the bumper from the brackets and hang the new one from the newly positioned/welded brackets. Looks and feels totally stock!
I did have to remove the fan shroud also, but with some home-made brackets for it, it will soon be back on too.
Good luck.
Good luck.
Might be a little late with the info but... I did my 3" body lift in my garage by myself. I unbolted the shift linkage and bolted in a piece of 1/4" steel. saved from having to weld it. The brake lines, fuel filler, battery cables, and wiring all had enough slack to allow the 3" stretch. I too lifted and remount the bumpers. (a bit of a pain) As far as the fan shroud I notched the bottom of it and put it back on. I did this about 2.5 yrs ago and have no overheating problems or anything else. BTW mine is a 1988 Bronco 302. I might be a lucky one but with limited cash it was the way to go for me.
