BEST gas treatment! - Ford Truck Enthusiasts Forums
General Automotive Discussion
BEST gas treatment!
Old 06-24-2005, 10:03 PM
Dustin_86 Dustin_86 is offline
Dustin_86 is starting off with a positive reputation.
Question BEST gas treatment!
What is the best fuel conditioner Not octane booster for my 99 zx2 with 92k miles.
Dustin
Old 06-25-2005, 05:17 AM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
Why do you want/need a fuel condtioner?
I'm just curious.
Old 06-25-2005, 07:52 AM
modar modar is offline
modar is gaining momentum as a positive member of FTE.modar is gaining momentum as a positive member of FTE.
Currently, many gasoline retailers provide fuels with lower-quality additive packages that can build up deposits on fuel injectors and on intake valves.
TOP TIER Gasoline Retailers
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline
Old 06-25-2005, 04:46 PM
tdister's Avatar
tdister tdister is offline
tdister is gaining momentum as a positive member of FTE.tdister is gaining momentum as a positive member of FTE.
Red line. Bmw approves it for constant use. People think that the detergents in gas are enough, but a few companies(gm comes to mind) are complaining that customers still see build-up with ALL brands of gasoline. It provides an upper cylinder lube as well as a few other benefits. Been using it in my truck since I got it.
Old 06-25-2005, 08:24 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
The very best product you can buy that actually works to remove deposits is SEA FOAM. You can find it at Napa, Carquest, O'Reillys, Checker/Schucks/Kragen, and most other Auto Parts stores.
Old 06-25-2005, 09:16 PM
tdister's Avatar
Is it going to be used full-time? If it is then I wouldn't recommend anything but Red Line (at the 100 gal. dilution). Not saying there aren't other suitable products, just none that I'm aware of. Not that BMW is the end all/be all (usually they know what they are talking about though), but they also say Chevron-techron is safe to use (and effective), but only twice per oil change (they have much longer oil changes than we do, fwiw). It builds-up in the oil and can harm the motor, supposedly, if used more than that.
Matts72
I thought seafoam was just poured into the throttle body/carb (i think they also have a spray), do they also have a fuel treament? I've heard that it's good stuff though.
Old 06-25-2005, 10:56 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
the same sea foam you put through the throttle body/carb is what you put in the tank. If you read the can it states that... it is actually the only way i have used it, and it is very effective.
Old 06-25-2005, 11:16 PM
Matts72's Avatar
I prefer the spray "Deep Creep" for throttle bodies and carburetors, and Sea Foam for the gas and crankcase.
It says its good for diesels, but I recommend the Lucas fuel treatment PN 10003, 10009 for diesels. Power Service makes a great product for diesels as well, but again, the viscosity is not there in the PS products.
Old Blue Dustin Jacobson 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-17-2008 12:50 PM
Dustin and his 10K post. preppypyro Manitoba / Saskatchewan Chapter 4 05-16-2008 12:58 AM
Best way to clean 30 yrs of grease? Dustin_86 1973 - 1979 F-100 & Larger F-Series Trucks 16 03-03-2006 01:57 AM
Delo 400 or M1 Dustin_86 Oil & Lubrication 8 02-15-2006 01:50 PM
How many Dustin's are there on here? klatt_89 General NON-Automotive Conversation 6 01-25-2006 05:18 PM
Tags
ford, gas, treatment, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
