1999 key switch
Unless they have changed things from a few years back...(about 6), then you need to turn the key to the ON position, then on the bottom of the switch, you will see a hole. Using something like a pick, you press in on a "release" then slide the cylinder out. Then you can install a replacement. But this will require a new key unless you take it to a locksmith and have them re-key the new ignition to fit your existing key. That may be the way to go so you don't have to get a new key/chip and have to re-program.
Someone chime in if I am missing this one!
