cab/frame compatability, what do i gotta do?
i have a 77 shortbed single cab with a decent front clip, fair cab, and no bed. i have a buddy who has several nice 67-72 cabs, clips, grills, shortbeds, etc. he has no 4x4s. i luckily have a 390 4spd 4x4, pb, ps, etc and i would like to know what is different in the two cabs, clips, etc incase i am wantin to do some swapping to the 67-72 body. which i really want.
anything else big i need to look out for? engine/tranny/t-case all line up the same, steering column, wiring etc? many ppl on this forum performed that? i'm pretty sure i will but i like being prepared...so i'll have the best frame/susp, with to me the best lookin body. i'm actually already using all the clutch stuff from a 71 on it and it seems to fit the same. i guess i'll need to cut the fuel door out of a wrecked 04 f-150 or somethin and mount in the 67-72 bed. sure dont like a gas tank behind the seat. one other question..what the heck should i call the truck? with that done it will be a 67-79, f-100-f-350 2wd-4wd, heh heck its already made of about 7 trucks
the vin will have to be the one on the cab youre using for title use. the suspension is the same through 79. if your going to disk brakes and power steering and such you'll need to use the brake booster and if your old truck is manual steering use the column out of the donor truck and a few of the guys here have a wiring diagram for the column swap. use as much as you can from the donor truck. there are some articles on the tank swaps too so try to do a search for those articles.
i have the power stuff on the 77 chassis already. and the behind the axle gas tank so i think i'll just take the flip open gas door off a new f-150 or stang or somethin and graft it into the quarter panel for the 67-72 bed. are the frame lengths different or anything someone at work said they thought the 73-79 frame might be a couple inches longer, once again for singlecab shortbed
Johny Cash had a song about that...............years ago.
Bolt the bump to your chassis, you will have to adjust in the bed area to make things line up.
John
I would guess the floor pans to be different right off the get go. On which of your body styles you talkin' about?
http://www.ebay.com/itm/complete-cab-doors-and-hood-for-ford-1970-f-600-truck-/281294112366?pt=Vintage_Car_Truck_Parts_Accessories&autorefresh=true&hash=item417e6f866e&vxp=mtr&nma=true&si=HUMTp95BrKpxtfBrPu10OtZzhLE%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557Bought it on a "whim". Something different. Probably could mount it on a 72 1 ton I have or just for parts.
VIN F61CEJ51099 from registration found in glove box . Sticker on pillar is unreadable.
I checked these. Roof,doors,cowl are the same. F100-F750. Firewall is different. F100/350 is one and F500/750 is another.
