ford f-150 fuel shut off switch location - Ford Truck Enthusiasts Forums
Old 06-19-2005, 03:50 PM
theghostofchange theghostofchange is offline
theghostofchange is starting off with a positive reputation.
Question ford f-150 fuel shut off switch location
i need some help, my 1988 ford f-150 is apparently equipped with a fuel shut off switch on it. but i dont know where its at! and now my truck wont start, somebody please help me....it has a str8 6 engine
Old 06-19-2005, 03:52 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
my 88 with the 302 is on the firewall on the inside, just above the brake. did it just happen all the sudden or did it sputter out, or did you hit something?
Old 06-19-2005, 06:44 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome theghostofchange, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 06-19-2005, 08:17 PM
chrono4's Avatar
well try resetting the inertia switch, then check the fuel pump relay under the hood.
Old 06-19-2005, 08:36 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
check wires under the fuel pump relay, they corrode.
Old 06-20-2005, 11:38 AM
quicklook2's Avatar
check the fuel pump relay wire connections at the relay the wires may have broken or the insulation stripped off causing it to short also it isnt a bad idea to replace the relay itself. check the power wire to the fuel pump relay to see if it has pulled out of the plug.
Old 12-03-2005, 01:19 PM
Cool fuel gauge reads erraticly
someone please help! my fuel guage on my ford f-150 isnt working.when the gas tank is full the gauge doesnt move. but when it gets to a certain point, it will move side to side. when the gauge moves it will go to full and then to empty. when i turn to the right, the needle go to the full marker, when i turn the left, the needle goes the empty marker. please tell me what is wrong so i can make the necessary repairs to it thanks.
Old 12-03-2005, 02:05 PM
chrono4's Avatar
id say its time for a new sending unit.
Old 12-12-2005, 06:43 PM
Question sending unit
thought about something else, what if the sending unit is ok? i know there might be a way to check but dont remember how to do it. also, when the gas gauge reads full, the needle goes way past the full mark. it would run parallel with the bottom of the instrument panel...as i try to illustrate here:
E 1/2 F
\ <-------needle on gauge
this is what it shows after the gas falls below half i think...
E 1/2 F
_________ <-------needle on guage
this is what it shows when i fill the tank up, does this mean that the sending unit is still not working or does it mean something else, let me know asap....
Security Shut off Switch? redbug 1999 - 2003 7.3L Power Stroke Diesel 5 05-15-2014 08:06 PM
Fuel Pump shut off switch 1986 F150 snooky1966 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-26-2008 11:24 PM
Fuel Shut Off Switch Location? G Lube 1994.5 - 1997 7.3L Power Stroke Diesel 10 11-24-2006 11:26 PM
impact fuel shut off switch stage2 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2003 10:48 PM
crash fuel shut off switch? tommyhand 1987 - 1996 F150 & Larger F-Series Trucks 21 06-05-2003 01:31 PM
Tags
1987, 1988, 1997, 2005, button, f150, f250, ford, fuel, located, location, pump, shut, shutoff, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
