Valve adjustment 351 c - Ford Truck Enthusiasts Forums
Old 06-17-2005, 01:22 AM
Ken Nerlove Ken Nerlove is offline
Ken Nerlove is starting off with a positive reputation.
What is the proper procedue for adjusting the valves on a 351c with crane roller rockers? I have heard various different ways to do it. I believe the best way is to put the cylinder on TDC, turn the adjuster down until snugg, then 1/2 turn more? My understanding is that the location of the lifter on the cam lobe is critical. How do you know when the position is correct so you can do the adjustment (whatever that is) Do you have to do each cylinder individually or is there some sort of system that you can follow? Any info would be appreciated.
Old 06-17-2005, 01:26 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Well I believe the one I have heard the most is when the exh starts to open adjust the intake, when hte intake starts to close adj the exh, personally I tend to bring the cyl to about 20 deg before tdc on it's fire cycle, and adjust both valves.
Old 06-17-2005, 07:59 PM
tastyklair tastyklair is offline
tastyklair is starting off with a positive reputation.
Monsterbaby is right about the intake closing, exhaust opening part. Crane has a tech article on their website which explains the whole process.
Old 06-20-2005, 10:55 AM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
Here, this may be easier than trying to find it:
Make sure the rocker you're adjusting is on the base circle of the cam. Tighten the rocker down until there's no up & down play in the push rod (zero lash) then go another 1/4 - 1/2 a turn more so it compresses the lifter assuming they're hydraulic. You don't need to prime the engine first. Repeat the process for each rocker by following the firing order of the motor or you can bring #1 cylinder to TDC on compression stroke then adjust #1 I & E, #4 I, #3 E, #8 I, #7 E. Then turn the crank 180 deg and adjust #3 I, #2 E, #7 I, #6 E. Then turn the crank 270 deg and finish with #2 I, #4 E, #5 I&E, #6 I, #8 E.
Valve lash adjustment with filler gauge or pushrod broncoii87newbie 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 0 05-20-2015 09:08 PM
460 valve adjustment crewcab77 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 11-13-2008 11:18 AM
hydraulic valve lifter adjustment inliner Performance & General Engine Building 8 01-04-2008 09:01 PM
adjusting valves? merc62 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-09-2005 12:59 AM
Valve Adjust Zs514rd 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 10-20-2001 12:31 PM
Tags
351, 351c, 351m, 351w, adjust, adjusting, adjustment, adjustments, adustment, boss, cleveland, ford, lifters, solid, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
