Battery disconnect to reset computer - how long? - Ford Truck Enthusiasts Forums
Old 06-16-2005, 10:10 PM
somegeek somegeek is offline
somegeek is starting off with a positive reputation.
I've read anywhere from 30 seconds to 45 minutes with the headlights on to drain the system and reset the computer to adjust more quickly to new mods added on to the truck... question is - how long do I actually need to keep my battery disco'd to reset my computer? What do the ford technicians recommend?
I unplugged my battery for about 15 minutes. The radio retained it's presets. Does this mean the system was not drained completely to reset the computer or that the radio keeps the presets regardless if it loses power?
Thanks,
somegeek
P.S. - got a 3" exhaust from end of Y pipe back with the larger magnaflow installed today - sounds damn nice. :-)
Old 06-16-2005, 10:43 PM
bobbylh bobbylh is offline
bobbylh is starting off with a positive reputation.
Really not sure, but I would disconnect before going to bed and reconnect in the morning. That should give it plenty of time.
Good Luck
Old 06-17-2005, 11:28 AM
ChrisAdams ChrisAdams is offline
ChrisAdams is starting off with a positive reputation.
Two minutes is plenty. The radio has a reserve battery on some models that holds a charge for quite awhile. I never lost my stations even on my truck after two hours. I have lost my trip odometer miles each time.
Chris
Old 06-17-2005, 04:56 PM
I noticed the radio clock was reset but the presets were retained.
Thanks for the info.
Old 06-18-2005, 04:12 PM
MJEmerson MJEmerson is offline
MJEmerson is starting off with a positive reputation.
i thought 97 was the last year that you could reset the computer like that. will it turn off the check engine light also?
Old 06-18-2005, 05:11 PM
No, the check light is stored. You need a code reader to clear that. Scanguage, superchips etc.
Chris
Update on fuel gauge problem 05 F250 5.4L steelbill58 1999 to 2016 Super Duty 0 04-25-2014 02:00 PM
radio cuts out tony ciar 2009 - 2014 F150 4 11-17-2013 08:07 AM
reset computer now truck is dead! nolanb 1999 to 2016 Super Duty 6 06-21-2010 11:53 PM
Cream colored oil cap residue somegeek 2004 - 2008 F150 19 01-13-2006 09:41 AM
What's the Best (beefiest) Battery for Aerostar? Dracoscott Aerostar 15 11-04-2005 01:38 PM
Tags
2005, 2009, 2010, battery, computer, computer2006, disco, disconnect, f150, ford, long, pcm, reset, stereo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
