Bassani - stock single exit or dual rear exit?
Old 06-15-2005, 11:50 AM
somegeek's Avatar
somegeek
somegeek is offline
Looking at the Bassani stainless cat-back exhaust systems. Does performance or sound differ between the single stock exit or the dual rear exit systems?
Bx or Quiet Thunder? Kinda confused what the actual difference is between these systems.
Pondering adding some equal length headers as well.
Old 06-15-2005, 02:58 PM
2004 Screw's Avatar
2004 Screw
2004 Screw is offline
I don't think you will be to pleased with headers not that much gain's less then 15 hp to the rear wheel's .
And for the exhaust side exit is louder and if you run true dual's you will lose bottom end power unless your running 360 rwhp
If you wan't more power try tunner, intake, exhaust, under drive pully's, e-fan's, gear's and if that's still not enough power Charge it
Old 06-15-2005, 04:48 PM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
Bx is aluminized tubing with stainless steel welds, and Quiet Thunder is all stainless steel. Single stock will be louder, as well as theoretically perform better (see 2004 Screw's post). Equal lengths are always a great addition. I had the complete bassani setup on my last bronco, and it was an amazing system. I wouldnt hesitate to run it again.
Old 06-15-2005, 07:12 PM
les017's Avatar
les017
les017 is offline
I just put the Bassani single stock on my 5.4 lariat...LOVE it. A bit quieter than the Magnaflow but IMO it has a classier sound. Really opened up the system. It was put in after my AF1 intake.
A friend and myself have virtually identical Lariats and we have always been within 1 truck length on our races. We both have the AF1 intake...but he has Magnaflow exhaust. We are still within 1 truck length, so our performance gains appear to be virtually the same/similar.
He is now wishing he had gotten the Bassani also. Just likes the tone better.
Unless you are looking for loud the Bassani appears to be a great way to go!!
Old 06-16-2005, 10:23 AM
somegeek's Avatar
somegeek
somegeek is offline
Les017 - You go wtih the SS or the BX?
Old 06-16-2005, 06:12 PM
les017's Avatar
les017
les017 is offline
I ENDED UP with S/S. Actually ordered the BX but my local distributor screwed up and acquired the s/s. Gave it to me for BX price.
I tend to drive a lot of highway miles and even going to the office is 35 miles each way. Personally I think not ever getting the exhaust truly heated up is a major rust contributor. So therefore I felt the BX would be fine, especially since the muffler internals are still all S/S either way
Old 06-17-2005, 11:57 PM
BIG BRD's Avatar
BIG BRD
BIG BRD is offline
howa about a part number on the ss bassani system and the absolute cheapest place to buy it from? does any company offer dual side exit(tips) like the earlier harley f150.
Old 06-18-2005, 09:18 AM
les017's Avatar
les017
les017 is offline
go Bassani Catalog for a listing of the Bx (aluminized) and Quiet Thunder (stainless) systems for the 2004 F150. There are 3 of each and they are listed in the order of (1) stock single (2) Lightning-style and (3) dual out the back. BTW - so far bassani does not show any products for the 05's.
I got my s/s stock single from V8Power.com here in So Cal for $335...picked up and installed myself, so no shipping charges.
As far as Harley-style exit the only I have found was Gibson. I actually thought about getting a Magnaflow or Bassani SI/DO and getting the Gibson tails and do a mte up, but it all started to get to be more trouble than I was willing to deal with. Especially since the Gibson was loaded with footnotes given that I have the 36 gal tank, 18" spare and factory hitch.
Old 06-18-2005, 07:07 PM
massdog_FX4's Avatar
massdog_FX4
massdog_FX4 is offline
Say again best way to work the most power out of the 5.4, tuner, exhaust intake?...what else and in what order would you do it?
AceSC
2004 - 2008 F150
08-05-2007 06:25 PM
illuzion
1978 - 1996 Big Bronco
11-30-2005 12:14 AM
GotLift
05-25-2004 05:03 PM
Justin89
Exhaust Systems
12-09-2001 09:14 PM
Quick Reply: Bassani - stock single exit or dual rear exit?
