01 7.3 Jerks and Bucks
I have a 01 7.3 Auto 4X4, with 205,000 miles, over the last 30,000 or so miles it has gotten progressively worst at Bucking or Jerking. It does this anywhere from 30 mph to 65 mph. The higher the RPM the less you can feel it! What could be causing this? In the last 2,000 miles I have had the HPOP replaced (o-rings blew out) and a BTS tranny installed. I did not replace these thinking it would solve this problem. Over that same 30,000 miles, what I believe some people call Fuel Crackle has also been happening. Could (Crackle) be causing this? Planning on in tank fuel return mod!! Maybe the CPS, Speed sensor or the TPS!!
Thanks for any help!!
My 01 does the same thing. I just bought it with 92,000 miles on it. It now has 95K.
Does your problem come and go? My truck runs fine sometimes, and like garbage the rest of the time. My symptoms also go away when I engage cruise control.
Very interested to see what you have already tried and what you find out.
Good luck.
Good luck.
Originally Posted by MobeyDick
It feels like the Motor skipping but it could be the VSS. Tach RPMs don't fall, it is so brief I don't think it would. What the heck is VSS?
it can be checked w/ a scan tool.
I took it to the dealer about 2 weeks ago, for first time!! The trucks never had any engine codes and only two at all those had something to do with the T/C and it's electronics!
Good luck.
Good luck.
aggiect01
03-17-2014 11:38 PM
Eric Shaw
07-28-2013 09:54 PM
