Installation of front inner fenders. - Ford Truck Enthusiasts Forums
Old 06-13-2005, 02:44 PM
Delzell Delzell is offline
Delzell is starting off with a positive reputation.
I had to repalce the front inner fenders of my 56. I chose some stainless steel ones. I have heard that I have to install them before I install the fenders. Is this true or can I put the entire cab together the install the front fenders?
Old 06-13-2005, 03:25 PM
imlowr2's Avatar
imlowr2 imlowr2 is offline
imlowr2 is gaining momentum as a positive member of FTE.
You should be able to install the inner fenders without removing the outer fenders. We replaced a set on my friends 53 Truck. He made his own out of sheet metal but I would think it's the same procedure. It's basically a bolt in operation from underneath and on top. Where did you get your stainless one from? I've been planning to replace my inner fenders with the stainless ones.
Old 06-13-2005, 03:30 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack has a good reputation on FTE.Randy Jack has a good reputation on FTE.
Delzell -
If your new inner fenders have slots (or large holes) where they attach to the outer fender, you can mock everything up without the outer fenders. Your hood should also be part of the mock up so you know you have a good fit at the cowl.
The CRITICAL part is that everything is square to the cab, beginning with the radiator support. It must be parallel to the firewall and centered on the cab. The whole front sheet metal is supported by and attaches to it.
Personally, having had the front of mine apart a few times, I would hang everything together and jockey all for the perfect fit and gaps, especially between the hood/fenders and the hood/cab. You'll be surprised how long that can take. Then drill some 1/8 dia holes between mating parts (inner/outer fenders; inner fender/cab angle; inner fender/air dams; air dams/radiator support) so that after you disassemble and reassemble, everything comes back exactly to that perfect fit. I learned that little trick here, and it will be especially valuable after all the parts are painted and you want to avoid scratches.
Old 06-13-2005, 07:07 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Good luck on the install. I put a new set on two years ago from Mid-Fifty. After a week of measuring and trial fitting, I did have to trim about 3/4" off end of each inner fender. I believe that the 56 inner fenders are about that much longer than the 53-55 model. I'll be back in town on Friday if there is anything I can help with. Note: do not remove the plastic coating until the install is done. Jag
Old 06-13-2005, 08:09 PM
B/B ford's Avatar
B/B ford B/B ford is offline
Clean & Classy
B/B ford has a good reputation on FTE.B/B ford has a good reputation on FTE.
like jag red I too had to trim one end of inner stainless panels from mid-fifty, although I think it was only about 3/8 to 1/2 inch. Mine is a 56. You definitely need to install the stainless inner fenders before installing fenders and air deflectors. Wayne
Old 07-25-2005, 08:08 PM
I have started the inner fenders. It looks like I may have to trim some of the inner fenders. Does this cause a problem where they mount at the air deflectors up front?
Four freinds started to help me today. None of them them felt you were right. I had the entire front end together and it just wouldn't go in. Had to politely as posseble tell them I have heard I have heard it is easiest to fit the inner fenders not attached to everything else. So I do have the inner fenders on but it does look like I'll have to cut some down tomorrow. Just wondered if that causes a problem?
Old 07-25-2005, 08:28 PM
Randy Jack's Avatar
Del -
Assuming that your new custom inner fenders bolt up the same way the old ones do, the trimming should happen at the rear of them where most of the joint is covered by the cab attach angle.
The most critical thing about it is that the flange on the front of the inner fender establishes the air dam location. The air dam also has to mate with the radiator mounting frame. If the length of the inner fender pushes the radiator frame too far forward, the outer fender won't go on properly either.
If the radiator frame is where it always was, you cold just put the inner fenders on and use a straightedge accross the face of the inner fender flanges and measure to the radiator frame for how much to remove. If you aren't sure that the radiator frame is where it needs to be, mock ip everything and measure then
The rear attach angle and some oversize holes there will give you enough adjustment even if the inner fender trim isn't perfect, as long as its not too long.
Old 07-25-2005, 09:31 PM
imlowr2's Avatar
I'd like to install a set of those Stainless inner panels, however I heard they are very difficult to align and install. I don't want to remove the fenders etc just for the simple fact of scratching, breaking off paint or damaging body parts, just to put new panels on. If I get a set of stock panels off another truck, do you still have to remove sheet metal and measure to replace them?
Old 07-25-2005, 09:51 PM
Randy Jack's Avatar
Ed -
Stock inner fenders are already sized to fit without trimming. I'm not sure why the stainless are oversize.
I think it might be possible to remove and install inners without removing other sheet metal, but the size of them make them hard to wheel around without whacking something else. Chipping the paint on something would still be problematic.
Mine look like they could come out thru the wheelwell (with the wheels off) easier than the engine compartment because of the way they are captured by their cab attach angles.
Obviously, I haven't tried this myself.
Old 07-25-2005, 09:54 PM
B/B ford's Avatar
Clean & Classy
imlowr2, I'm not sure about stock inner fenders but couldn't you see if you can safely remove one? If you can then that should answer that question. But I can't see any way that I could have fit my stainless inners without taking the fenders and air deflectors off. They weren't so hard to align after cutting them, as mentioned above. R.J.s [How to] suggestions above are right on. Wayne
Old 07-25-2005, 10:39 PM
imlowr2's Avatar
I may have to try and take my inners out. Either way, I need to replace them. I believe the PO cut them with a torch to fit fender well headers, or cut them because the truck had a one piece front end at one time or the other. I still love the look of the SS one, but I may have to settle for original. Thanks for the advice guys.
Old 07-26-2005, 08:32 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I took out my inners without removing the fenders. The PO had cut off the back ends (with a torch!) when he flipped the front end. I plan to replace them with the SS ones.
Old 07-26-2005, 10:20 AM
Jag Red 54's Avatar
I would not attempt to replace the inner fenders with the outer fenders in place. The SS units require a lot of pushing to get them in place and to hold them while somebody else puts in the front bolts to hold them in place. This pushing would all have to be from under the outer fenders! That's right, you've entered the "Outer Fender Zone." Do not attempt to adjust your computer monitor. We control the vertical...We control the horizontal.. So, sit down as we explore the "Outer Fender Zone." (In my best Rod Serling voice.) Jag
Old 06-21-2008, 08:18 PM
ferguson777's Avatar
ferguson777 ferguson777 is offline
ferguson777 is gaining momentum as a positive member of FTE.
Would anyone have pics of the smooth, aftermarket inner fenders for a 53-55 (like you'd get from M-F or Hot Rods - installed but without the outer fenders mounted?
Mine didn't come with anyinstructions and I'm a little unsure how they should look.
Thanks,
Old 06-23-2008, 03:25 PM
Jag Red 54's Avatar
Sorry Fergie, this is the best view I have. I didn't think to take a picture before I put the fenders on. But if you moubnt the back flange loosely and then push the front toward the inside until those holes line up with the holes on the horse collar, you'll be in the right position. It's best to have somebody there to install the bolts when you are pushing. Jag
Hood bolts & nuts John R. Thomas 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-23-2015 09:47 AM
53-56 Smooth front inner fenders Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-10-2014 02:46 PM
Feel pretty good! Roelito78 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-01-2010 07:53 AM
1966 inner fender bender EDMist 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-17-2007 08:08 PM
65 - 66 inner fenders fomocoloco 1961 - 1966 F-100 & Larger F-Series Trucks 5 09-29-2002 05:17 PM
Tags
1973, 2004, 55, aligning, cab, compartment, custom, custominner, engine, fender, fenders, ford, install, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
