Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-13-2005, 10:54 AM
74fordhighboypickup 74fordhighboypickup is offline
Garage is empty, add now
74fordhighboypickup is starting off with a positive reputation.
E85 Alternative Fuel
There are several gas stations around here that have started selling this alternative fuel. It is made from corn and is 85 percent ethanol. Octane rating is 105. I know their website says on FFV vehicles should be used when running E-85.
What would it take to make my old 1996 F-150, 4.9 I-6 run it. It's about 30 cents cheaper a gallon and would make a heck of difference in the ole wallet if it was feasible.
  #2 (permalink)
Old 06-13-2005, 05:24 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
It can be done, but it all goes back to the old saying:
"Good, fast, cheap. You can pick any two."
For best results, you'd want to rebuild your motor to better support the ethanol. Start with higher compression. 12:1 would be about right. Next, you might have problems with rubber / plastic components in the fuel system. It is set up to work with 10% ethanol, and I doubt you'd have a problem on 85%. But be advised you might have to change a fuel pump and some lines, possibly injectors too. Some sort of intake manifold heating is highly recommended to get the ethanol to vaporize correctly.
Speaking of injectors, you need to put more fuel in with E85. The proper way would be to have a custom computer chip programmed for ethanol, and use a couple sizes bigger injectors.
You could probably just dump it in the tank and run it the way it is now, but your mileage will likely go down enough to negate any benefit. Plus, you'd likely have cold start difficulties.
  #3 (permalink)
Old 06-13-2005, 05:25 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
there are many threads in this forum about this, and many opinions. The only way to know for sure how it will work out is to do some research, and play with it a little. I have had some success running GM vehicles on it, but I have no Ford gassers to do it on. I have been told by a friend that tried it that he lost mileage on his 96 Taurus. My 94 Plymouth van did not run too well on it, was hard starting and lost mileage. Only on the GM vehicles did I maintain mileage and driveability.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #4 (permalink)
Old 06-14-2005, 08:01 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Quote:
Originally Posted by 74fordhighboypickup
There are several gas stations around here that have started selling this alternative fuel. It is made from corn and is 85 percent ethanol. Octane rating is 105. I know their website says on FFV vehicles should be used when running E-85. What would it take to make my old 1996 F-150, 4.9 I-6 run it. It's about 30 cents cheaper a gallon and would make a heck of difference in the ole wallet if it was feasible.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
