3.08 gear ration????
Old 06-13-2005, 10:45 AM
Schuby's Avatar
Schuby
Schuby is offline
Hey guys... I have a 2000 F-150 4.6L manual 2wd...flareside...& the original sticker is in the glove compartment says that is has 3.08 gear ratio.
What the heck is 3.08 good for...I have heard of 3.55...3.73(lightning) ...4.10....
but 3.08....what are the pro's & cons for a 3.08 ratio????
Old 06-13-2005, 06:32 PM
BSHORT's Avatar
BSHORT
BSHORT is offline
Received 1,362 Likes on 704 Posts
3.08 Is Good For Flying Down The Highway Or Rollin' Around In 3rd Or 4th Gear. 3.08 Brings Your Towing Ability Down As Well As Your Operating Rpm's. 3.08 Is Almost Useless In A Truck. 3.08 Was Common In Older Vehicles W/3 Speed Autos. I Had 3.31 In A Truck And I Thought That Was Bad. I Cant Imagine 3.08 W/overdrive.
Old 06-13-2005, 07:46 PM
jcstratt's Avatar
jcstratt
jcstratt is offline
The rear gear ratio of 3.08 in a 2000 M/T (which has a 5th gear ratio of 0.8) is actually pretty close to being the same final drive ratio at the wheel as a 2000 A/T (which has a 4th gear ratio of 0.7) with a rear gear ratio of 3.55.
Old 06-13-2005, 10:21 PM
cowboydown's Avatar
cowboydown
cowboydown is offline
3.08 is good for high end. Acceleration sucks, but if you have the hp, it can help you stretch out your top end speed.
Old 06-14-2005, 07:47 AM
Schuby's Avatar
Schuby
Schuby is offline
I was thinking about switching to a lower ratio....good idea or bad. It is pretty much a street truck...that's what I want it to be...somewhere in the class of a lightning after putting mods & accessories on, but it won't have all the power an L has. How much would it cost to change ratio's???
Old 06-14-2005, 08:13 AM
cowboydown's Avatar
cowboydown
Ok, if you switch out your gears, go for at least 4.10's or you will regret it. The only thing is, you will lost out a bit on your optimal transmission gearing, so you will shift at lower speeds and your top end will be cut down. Good thing is, your acceleration will be quicker.
Cost: Depends on if you do it yourself or not. Gears usually cost around $200 and the fluid and seals and whatnot will cost another $50. If you get a shop to do it, it will probably run you around $1500. If you do it yourself or with a mechanically inclined friend, it will cost you quite a bit less, but you have to be careful or you can screw things up.
Old 06-14-2005, 10:07 AM
gui88ford's Avatar
gui88ford
gui88ford is offline
i had my gears changed in my mustang at a shop in Pottstown, PA for 220 some dollars....i suplied the parts.....now, that was just one rear.....and yeah, 3.08's have to suck.....i have 3.73 in my truck and i'd like to go to 4.10's, expecially after i get my new tires and wheels.....so, do yourself a favor and go to 4.10's
Old 06-14-2005, 10:22 AM
Schuby's Avatar
Schuby
Schuby is offline
what about gas mileage...any difference between the two...& how much quicker will it make my truck.???? I don't know nothing about ratio's
Old 06-14-2005, 10:45 AM
gui88ford's Avatar
gui88ford
well, gas mlg will most likley go down....acceleration will go through the roof compared to a 3.08..you will lose some highway high end speeds because your making the gears shorter but in the end it's well worth it.....i couldn't give you a number on how much your gas mlg will drop....a guess would be that it would drop mabey 2mpg or mabey 3 at teh most.....thast just a guess thou
Old 06-14-2005, 02:03 PM
Schuby's Avatar
Schuby
Schuby is offline
I like the acceleration gain...big smiles there...but this day and age...gas is gold...the price of it that is...what are some tips...go with 4.10...lightnings have 3.73 (I think)...????where can I buy them at besides FORD?
mr. wackodog
10-16-2012 08:06 AM
Modified
13
03-03-2006 11:31 AM
ustolemycupcake
28
03-21-2005 10:11 AM
FordDrvr
21
07-22-2003 11:30 PM
pcman
22
10-21-2002 02:18 PM
Quick Reply: 3.08 gear ration????
