460 egr - Ford Truck Enthusiasts Forums
460 egr
Old 06-13-2005, 08:00 AM
mooney456 mooney456 is offline
mooney456 is starting off with a positive reputation.
460 egr
will a 1985 460 engine with egr survive without the egr???
thanks
mooney456
Old 06-13-2005, 08:23 PM
loveoldtrux loveoldtrux is offline
loveoldtrux is starting off with a positive reputation.
sure - mine does. In California though, I think you better be wary.
Old 06-13-2005, 11:45 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
I always get a new gasket and then fab a 1/4" aluninum plate and block the egr off leaving the egr in place so the smog cops won't wet themselves. If yours in carburated (should be) you make have to do some jet changes.
Old 06-19-2005, 12:58 PM
Godzill992 Godzill992 is offline
Godzill992 is starting off with a positive reputation.
Trans Dapt offers carb spacers that will replace your original EGR plate & close off the vaccum lines in the intake manifold. Simple install, pull the carb off and the egr spacer, throw them away and mount this one. I got a model 2199 when I switched over my carb to a square bore holley 4160. I havent got mine up and running yet (see prior posts) but I've heard excellent things about them. Really well enginered. You can get them at jegs for around 50 buck to your door.
dana 60 disc brakes mooney456 Clutch, Transmission, Differential, Axle & Transfer Case 0 10-03-2005 04:19 PM
stans headers mooney456 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-22-2005 11:15 PM
advance adapters overdrive unit mooney456 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 10-16-2004 09:53 PM
Batteries mooney456 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-06-2004 11:21 PM
2004 escape mooney456 Escape & Escape Hybrid 0 06-11-2004 07:43 PM
Tags
460, 85, carb, egr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
