Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-11-1999, 02:56 PM
Rich molta
Posts: n/a
Trouble starting when hot
I,ve got a 1989 f-150 5.8L that runs fine but does not start well when the engine is hot. When the engine is cold it cranks right over, when it;s hot the starter binds, sometimes cranking over, sometimes it just grinds till the battery drains. If I wait awhile untill the engine cools down and try it again it usually starts right up. The battery is good, the timing is on, and the starter is brand new. I also cleaned all the electrical connections I could find. Can anyone tell me where to look next?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-11-1999, 03:21 PM
Rich Molta
Posts: n/a
Correction - it's an f-250!
  #3 (permalink)
Old 11-11-1999, 10:24 PM
Phil is starting off with a positive reputation.
Wow....I would think that you would have to make a heat shield somehow.....does the exhaust run close to the starter? That's what it sounds like to me....make a shield for the starter or wrap the pipes in that area....I've heard of this happening before.....
  #4 (permalink)
Old 11-12-1999, 03:09 PM
Jason Gaiser
Posts: n/a
I have a 83 f-250 with a 460 that does the same thing. How I solved my problem was to try not to turn the key as far as you normally would. More than likley your problem is in your ignition, than your starter. you probaly have a spot worn into your ignition and when it gets hot you notice it more than when its cold
  #5 (permalink)
Old 11-15-1999, 09:40 AM
Phillip Guidry is starting off with a positive reputation.
When it comes to a Ford starter, you need more CCA's(cold crank amps)in your battery.Plus,the physical size makes a difference also.If you most run a Group 24,get at least a 72 month or more battery,that'll get you about 650 CCA's. In a Group 65,you can get by with a 60 month because of it's increased capacity due to larger plates & more acid.Now, none of this helps if your existing battery has a slight defect in it! Have it load tested several times at once to verify the voltage doesn't drop off after a couple of loadings.And last,if you have those emergency repair term's on your cables,replace them,don't just clean them.And change any 6 gauge cables to at least 4 ga.
Phillip
__________________
Phillip Guidry
Southern,LA
98 F150 2wd 3dr 4.6l Auto 80k
88 F150 2wd LWB 4.9l 4-spd Granny 195k (sold
98 FXDL
83 VT750C
08 Fusion V-6
  #6 (permalink)
Old 11-15-1999, 05:17 PM
Fast Eddie
Posts: n/a
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
