Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-12-2005, 10:03 PM
FireMan208's Avatar
FireMan208 FireMan208 is offline
Garage is empty, add now
FireMan208 is starting off with a positive reputation.
keroscene?
Hey folks,
Earlier today I was talkin' with an older gentleman about my PSD. He asked if in the winter I mixed about 5 gallons of keroscene in my diesel @ fill-ups? Just wonderin the theory behind this? Also what exactly is boost? Still new to the game of diesels. Thanks!!!
__________________
'99 F250 Super Duty 4x4 PSD Ext. Cab, 4" Exhaust, Tymar air intake, 52" Code 3 MX7000 All-Light Light Bar, Whelen 100W Siren (Grill Mount), JVC 180W CD Player.
  #2 (permalink)
Old 06-12-2005, 10:44 PM
Skeeter2221 Skeeter2221 is offline
Skeeter2221 is starting off with a positive reputation.
Fireman 208
First off if 208 is your fire unit number, my unit number is also 208 PD. Well any way I've often heard of the old farmers around here mixing kerosene w/ diesel during the winter inorder to keep the diesel from jelling. Talking to a diesel mech. I found that it may not be the best practice. I've too mixed it together but only when the temp is 0* and diesel anti jelling wasn't available. I use the diesel kleen anti jell during the winter and reg. diesel kleen though the summer months.
  #3 (permalink)
Old 06-12-2005, 10:53 PM
Flinno18 Flinno18 is offline
Flinno18 is starting off with a positive reputation.
Flinno18
Boost is the pressure at which your turbo compresses the air the engine is taking in. The ability to compress air means more flows into the engine which in turn means the engine is able to make more horsepower. (More air to mix with the fuel.) Umm I think that is the simplest terms I can put it in. If there is anymore to it please add on for me! I hope that scratches the surface for you.
__________________
2006 F-350 PSD DRW
  #4 (permalink)
Old 06-12-2005, 11:08 PM
FireMan208's Avatar
Thanks Guys,
Yea Skeeter my FD unit used to be 208, now its 204 ( got bumped up to Lt. ).
__________________
  #5 (permalink)
Old 06-13-2005, 09:21 PM
johnny8's Avatar
johnny8 johnny8 is offline
johnny8 is starting off with a positive reputation.
kwikordead posted this in another thread... it helped me to understand the way the turbo works... "you have to understand why things work the way they do on a starship..."
"You'll only get boost when there is enoughtvelocity to drive the turbine. At idle there is just not enough heat generated inside the combustion chambers to expand the air that much. Besides at idle you don't need that much fuel energy to maintain engine speed. So there is very little pressure on the exhaust side to drive the turbine. Now if you start to give it some throttle, more fuel gets injected, more heat gets generated inside the combustion chamber and you get greater expansion of the air trapped inside the combustion chamber. Since the chamber doesn't get bigger that greater expansion has to go somewhere and it does in the form of increasing PSI inside the combustion chamber and then the exhaust manifold once it exits the engine. Now there is no longer any constraints on the size of the air and like water, air pressure always seeks it's own level. So it starts blowing forcefully out the turbine wheel housing as it's the only way out. Turbine starts to spin and boost starts to be generated. It's all about the amount of fuel injected, the amount of heat generated as a result and the resulting exhaust velocity through the exhaust housing." - KwikorDead
__________________
2002 F350 7.3 Auto 4x4 SD SRW SB
46637 "kwik wix" filter mod
Predator tuner
sonnax kit
walker btm
wastgate mod
dipricol gauges
tru-cool tranny cooler
superior compressor wheel
dual valve boost fooler
  #6 (permalink)
Old 06-14-2005, 12:37 AM
fixnair's Avatar
fixnair fixnair is online now
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
Smile
Boost is an elevated intake manifold pressure. As you open the throttle, the increase in engine speed causes an increase in exhaust flow which drives a turbine wheel. The wheel is connected to a compressor wheel. The faster the exhaust side turns, the faster the compressor wheel turns forcing air into the intake manifold.At manifold pressures below 7 PSIG the engine is merely boosted. Once you exceed 7 PSIG then your engine is supercharged.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #7 (permalink)
Old 06-14-2005, 09:57 PM
Diesel Truck Driver Diesel Truck Driver is offline
Diesel Truck Driver is starting off with a positive reputation.
Kerosene is basically the same thing as #1 fuel oil, subtle differences but for the price it is much cheaper to use #1 in your tank. All of this also depends on the temp being very cold, otherwise you are giving away your money for less mileage.
How do I know? Check out the post on what the names mean.
  #8 (permalink)
Old 06-14-2005, 10:41 PM
MasterTrim MasterTrim is offline
MasterTrim is starting off with a positive reputation.
Quote:
Originally Posted by FireMan208
Hey folks,
That will basicly thin the diesel, old timer thing to do. If you can get Kero cheap mix it with WVO. I know some farmers doing that in there tractors 50/50 and a friend that runs 90/10 WVO to Kero in there diesel generator and it will start in -20 weather. WVO is alot cheaper than diesel too.
__________________
Ken
87 F250 6.9 ZF 5/spd, 3.55 gears, 4x4, std cab, 8-6 Westurn snow plow. SOLD!!!
Bought 96 F350 CC 4x4 Longbox SRW
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
