Valve Cover is on - Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader:
Valve Cover is on
Old 06-12-2005, 04:16 PM
Violjohn78's Avatar
Violjohn78 Violjohn78 is offline
Violjohn78 is starting off with a positive reputation.
Valve Cover is on
Got the junkyard "power by ford" valve cover and painted teh air cleaner to match
Old 06-12-2005, 07:34 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
That is the sweetness! Looking good John, but I still don't see those headers down there What paint did you use? O yeah, I'm going to PM you how to do linkable pics so as not to attract to much moderator attention
Old 06-12-2005, 08:07 PM
Violjohn78's Avatar
Just used rustoleum bare metal primer, then painted over that with Semi-gloss engine paint. Actualy putting in the 3.27 gears and TracLock next weekend that's going to make a huge improvement over headers.
Picture of it Primed look no pic in post ;-)
Old 06-12-2005, 09:52 PM
Gear swap sounds cool. Where did you find 3.27 gears? I think you told me where at the meet, but I forgot. Looking at your project is getting me movitvated to do mine. Finished cutting EVeRYTHING off my frame, gonna prep and paint next week
Heres what i call a linkable pic
Old 06-12-2005, 11:58 PM
Violjohn78's Avatar
3.27's i got off ebay, out of a ford cobra have about 12k miles on em. Better than my 180K 2.47's Paid 30 bucks for them shipped i believe. The traclok was about 120 shipped, also from the bay. Evil place that ebay >
Old 06-17-2005, 12:37 AM
Violjohn78's Avatar
Gear Swap
Ok, well just an update on my truck, The rear is off the ground, and i've completely disassembled the rear diff. Have the bearings on the Diff, and Ring gear, have done all my measurements and will be setting up my 3.27's tomorrow Whoohoo :-)
Old 06-19-2005, 09:06 AM
Violjohn78's Avatar
Yay, I"m done. Well 3.27's are in (finished friday night). This is A WHOLE lot better than 2.47's. Gearing is just right. On the Hwy at 65 i'm cruising at 2k. ARound town driving is painless now,especially starting out. Used to have to run in 2nd gear until i was up to around 35-40 before I could shift into 3rd but wouldn't have any power. LS is nice too. Got up a steep part of my yard and when that first got o the grass started to slip the other side grabbed and i kept moving :-)
Old 06-19-2005, 12:02 PM
Sounds great! I experienced the same thing with my truck, it was a whole new truck! Even gained a little mileage too. Of course at 65 I'm cruising 2500 rpm I've got a LS in my garage I wanted to install, but I can't set gears to save my life. Ended up buying the whole rear end. LS is going on EvilBay, try and make back alittle of my money pit
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
